ragico
Post by ragico »
@quietvoid
Will you implement AV1 codec support in your excellent dovi tool?
quietvoid
Post by quietvoid »
ragico wrote:
Thu Sep 04, 2025 10:30 pm
@quietvoid
Eventually, very busy these days.
deadchip12
Post by deadchip12 »
@RESET9999
Do you know the best way to move my coreelec cpm a14 build from the existing usb stick to another usb stick with all the settings intact?
deadchip12 wrote:
Mon Sep 08, 2025 4:40 am
@RESET9999
no idea, ask on the avsforum thread
geofox784
Post by geofox784 »
May be a dumb question, but I've done a fair amount of research and still don't 100% understand.
In the Dolby Vision Stuff google sheet I see chart "ENCODER GROUPS TO AVOID BECAUSE THEY DONT ENCODE DV FEL PROPERLY"
I have a AM6B+ so I can playback DV Profile 7. I wanted to confirm that I understand encoding correctly. If the group that created an mkv left the file as a Profile 7 release instead of baking the FEL / encoding it into Profile 8, is no encoding actually occurring when the MKV is created from the original bluray disk files? Wouldn't this be a lossless packaging of the data directly into an MKV format?
For example, if a release is titled "███.2025.2160p.UHD.BluRay.REMUX.DV.P7.HDR.ENG.TrueHD.Atmos.7.1.H265-BEN.THE.MEN", does it matter that the release group is in the "avoid" list?
Mediainfo shows "HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible"
Rororororo
Post by Rororororo »
Hello @RESET_9999, could you provide more details about T1-T2-T3-T4 analysis and how it affects metadata, or point to a relevant source?
I tried googling it, quoting it with “resolve studio,” etc., and searching this topic, but I wasn't able to find anything except replacing L1, L2, L3, etc., which doesn't say much.
Thanks !
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
geofox784 wrote:
Mon Sep 15, 2025 1:51 am
if it's a remux, it should be fine...
That list is only for the encodes and that guy ben the men encodes are ridiculously bad: https://slow.pics/c/Yp0F0UWf
Rororororo wrote:
Mon Sep 15, 2025 10:53 am
Thanks !
https://slow.pics/c/OA0pupEN?canvas-mode=fit-width
https://professionalsupport.dolby.com/s ... uage=en_US
coopzr
Post by coopzr »
The release of the recent dim movies (F1, Jurassic World Rebirth, and Superman) got me thinking... Is there any brightness (or lack of) where it would be better to watch the SDR release instead?
As my TV is not professionally calibrated, I think it's still better to go HDR in my situation, as I know the brightness will better match the artist's intent (as opposed to my SDR brightness, which is just eyeballed).
geofox784
Post by geofox784 »
Have you found that most releases labeled "remux" are truly lossless remuxes, or do you have to watch out for releases labeled as a remux, but that are actually an encode that has been labeled as a remux that may have some small changed like changing from P7 to P8?
LV8HD
Post by LV8HD »
@RESET_9999 do you always generate new Dolby Vision metadata even for CMv2.9 retail P7 with manually done trim passing?
coopzr wrote:
Tue Sep 16, 2025 3:24 am
These movies are only dim compared to SDR if you don't watch SDR at reference level (100-150nits). At reference level, the HDR in these movies still win, see my youtube comparisons.
geofox784 wrote:
Tue Sep 16, 2025 3:25 am
if the filename says remux, it's most likely a remux. P8 ones are probably hybrid with metadata taken from web source.
LV8HD wrote:
Tue Sep 16, 2025 10:28 am
only the 4000nits MDL ones
LV8HD
Post by LV8HD »
RESET_9999 wrote:
Tue Sep 16, 2025 11:02 am
Why is this?
LV8HD wrote:
Tue Sep 16, 2025 11:07 am
Why is this?
only that causes an issue on my G5:
https://docs.google.com/spreadsheets/d/ ... 1289366200
daffie
Post by daffie »
Has anyone noticed that the scene cuts (workflow 2-1 in Dovi Scripts) for Alien from 1979 are rather strange and unusual compared to almost all other movies. The UHD is HDR10 plus and I ripped it myself from disc with makemkv. Same goes for the H265 remux you can find on the Internet. So my rip is definitely fine.
Anyone noticed the same? Theatrical Cut by the way.
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
If you're referring to the HDR10+ scene cuts, we no longer use them when generating DV. They often don't make sense, and Resolve's scene cut detection does a better job.
daffie wrote:
Sun Sep 21, 2025 2:45 pm
