LibreDrive for Pioneer drives
Post by Billycar11 » Sat Sep 06, 2025 7:46 pm
personforsure wrote: Sat Sep 06, 2025 7:32 pm Hi. I have been buying and returning external blue ray rippers lately, trying to find one that would work to read and rip 4k UHD. This is the last one I got and it has firmware from 12/2022. I did not update this, this was fresh out of the box. I did not download a Pioneer utility to update firmware. When I looked at the guide and many posts, it has been written as 'after 12/2022'. Is this the bad firmware? I got this from amazon and it was listed as BD-RW BDR-XD08S, the box matches this (of course this could be repackaged). Does anyone have advice on if this is supported out of the box? Its not playing 4kUHD blue rays, only regular blu rays.
I thought I was getting this model (from the guide: drives that Currently work are:
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins)
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 58
Drive platform: Pioneer RS9330
Firmware version: GENE
Email me if you want a remote flash for this drive it is experimental
And costs extra email me for details below
Post by MartyMcNuts » Sun Sep 07, 2025 12:15 am
Revision: 1.02
Firmware is no good since it is after 11/2022 (from (including) 12/2022 is no good).
KainSwiss
Post by KainSwiss » Sun Sep 07, 2025 9:24 am
Any info on the model listed below? can't get it to work with UHD Movies
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number:
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 60
Firmware version: ID05
Post by MartyMcNuts » Sun Sep 07, 2025 9:53 am
KainSwiss wrote: Sun Sep 07, 2025 9:24 am Any info on the model listed below? can't get it to work with UHD Movies
Revision: 1.03
Serial number:
No as the firmware is post 11/2022. You will have to wait for future support.
KainSwiss
Post by KainSwiss » Sun Sep 07, 2025 11:27 am
Oh bugger! Thanks for the response 😊
EthanW
Post by EthanW » Sun Sep 07, 2025 3:53 pm
Is this Pioneer BDR-212ULBK Libredrive possible?
Product: BD-RW BDR-L07SH
Revision: 1.10
Serial number:
Firmware date: 2014-06-27
Highest AACS version: 76
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS8000
Firmware version: ID92
Post by Billycar11 » Sun Sep 07, 2025 3:55 pm
EthanW wrote: Sun Sep 07, 2025 3:53 pm Is this Pioneer BDR-212ULBK Libredrive possible?
Revision: 1.10
Serial number:
Nah what's not a 212 it's a L07
You got scammed probably a re stickered drive
tomhitchman
Post by tomhitchman » Wed Sep 10, 2025 4:46 pm
PIONEER BD-ROM BDC-TD04 (FW1.00) USB <----- any chance this is capable of using libredrive?
Aficer
Post by Aficer » Wed Sep 10, 2025 5:27 pm
Any UHD hope yet for my Pioneer BDR-S13U-S?
OS device name: F:
Product: BD-RW BDR-X13U
Revision: 1.04
Serial number: CGDL300347UC
Firmware date: 2023-08-01
Highest AACS version: 77
Firmware version: ID29
personforsure
Post by personforsure » Wed Sep 10, 2025 10:47 pm
Billycar11 wrote: Sat Sep 06, 2025 7:46 pm
Revision: 1.02
- Thank you. I appreciate your response and services offered. I ended up returning it and getting the archon drive from the Guide. Powershell doesn't like X86 file name so I am trying the SDFlasher. Overall I think this was the better choice.
Product: BD-RE BU40N
Revision: 1.02
Bus encryption flags: 1F
Highest AACS version: 82
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Post by Billycar11 » Wed Sep 10, 2025 10:51 pm
personforsure wrote: Wed Sep 10, 2025 10:47 pm
Revision: 1.02
oof see latest guide update the newest archgon no longer supports flashing
and the pioneer was a much better drive and flashing is about to come out
personforsure
Post by personforsure » Wed Sep 10, 2025 10:57 pm
Billycar11 wrote: Wed Sep 10, 2025 10:51 pm
Revision: 1.02
Welp, I could not flash this one at all so I guess I will return this one too. Thank you
Post by Billycar11 » Wed Sep 10, 2025 11:02 pm
personforsure wrote: Wed Sep 10, 2025 10:57 pm
Revision: 1.02
you can take it out of the case and flash it
NotJoseph
Post by NotJoseph » Fri Sep 12, 2025 2:32 am
So, I've been lucking for a few months and just got a Blu-ray for $70, NIB.
I cant make heads or tails of this thread and the "BDR-209" in the UHD Drive channel... Drive info below. Is it UHD possible or just LibreDrive?
Product: BD-RW BDR-209
Revision: 1.10
Firmware date: 2013-09-10
Drive platform: Pioneer RS8600
Firmware version: ID81
Post by Billycar11 » Fri Sep 12, 2025 6:18 am
NotJoseph wrote: Fri Sep 12, 2025 2:32 am So, I've been lucking for a few months and just got a Blu-ray for $70, NIB.
Revision: 1.10
email me your drive info section see email below
