I tried to open this Blu-ray disc with MakeMKV,
but it shows "Volume key is unknown" and I cannot proceed.
I am attaching the dump file (.tgz) for analysis.
The disc title is "NTS_20240314_BD".
Thank you for your support.
Dump file for AACS v82 disc
mimimi
- dump_FW_655F5A02B3616994423D.tgz
- (475 Bytes) Downloaded 165 times
Re: Dump file for AACS v82 disc
So far, there is no way for anyone, especially the MakeMKV author, to determine just what disk you're referring to.
Please put the disk NAME in the subject field, email the generated dump file (it will be bigger than 475 bytes!) to svq@makemkv.com, and (optionally) post it where it can be retrieved by the people associated with the keydb database,
This appears to be a firmware dump, not a disc dump!!mimimi wrote: Sun Sep 07, 2025 12:05 pm Hello,
