This set of eight discs use a newer version of AACS protection. Backup failed.
I already reported this using the link in the error message.
A link to the AACS .tgz dump files are below in case anyone can follow this up more quickly.
Always appreciative of forum members support.
The Alfred Hitchcock Hour: Season One (1962-1963)
kzwfwd
Re: The Alfred Hitchcock Hour: Season One (1962-1963)
Instead of creating all of these threads, can you just make these posts in the Public KeyDB Disc Submission thread: viewtopic.php?f=12&t=38293 That's what it is for! It's better for everyone to have them all in the one place!!kzwfwd wrote: Sun Sep 07, 2025 7:24 am This set of eight discs use a newer version of AACS protection. Backup failed.
kzwfwd
Hi MartyMcNuts,
I have a Pioneer drive (purchased from you) which is unfortunately not supported on Public KeyDB Disc Submission thread.
Sincerely,
kzwfwd
Sincerely,
kzwfwd
Dumps from some Pioneer drives can be used, not the BDR-UD03 and BDR-UD04 though. If using one of those drives, why are you posting the dumps? There's no point as only Mike can use them to add to MakeMKV's hashed keys, which is what the email submission to svq@makemkv.com is for.kzwfwd wrote: Sun Sep 07, 2025 9:25 am Hi MartyMcNuts,
Sincerely,
kzwfwd
I just checked out one of your dumps and since you are using a S13J-X, your dumps should be usable for KeyDB.
