Jurassic World Rebirth tgz new key type
Tok72
Post by Tok72 »
This also indicated a new AACS version v82.
This is for the standard Blu-ray. The 4K UHD rip with latest update of keydb.cfg works.
Re: Jurassic World Rebirth tgz new key type
Tok72 wrote: Sun Sep 07, 2025 3:13 am Jurassic World Rebirth
Did you email the dump to svq@makemkv.com as per the standard process? If not please do so.
I have also sent you a PM.
Tok72
Post by Tok72 »
Yes I did send the email around same timeframe as post
ivan@toulousenet.de
Post by ivan@toulousenet.de »
I have the same issue. Received rebirth yesterday and tried to rip it, without success. MakeMKV says it uses a new AACS protection. I used the inform link.
gensplejs
Post by gensplejs »
Same here
Using LibreDrive mode (v06.3 id=64754CF46FCA)
This disc uses newer version of AACS protection. Please let us know about it by visiting https://www.makemkv.com/a/?7MZEZZFmwvKt ... LFbLot0Q==
Saved AACS dump file as C:\Users\jens/.MakeMKV/MKB_v82_Jurassic_World_Rebirth_70C2.tgz
I sent the file to svq@makemkv.com and pressed the link for informing about the new AACS version
Strange thing is the disk information says
Disc Information
Label: JURASSIC_WORLD_REBIRTH
Timestamp: 2025-08-14 13:03:46
Protection: AACS v82
Data capacity: 40.4 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
While the Makemkv changelog says support for AACS v82 was added in v1.18.0
I am using makemkv 1.18.2 so im a bit confused.
gensplejs
Post by gensplejs »
So apparently downloading the keydb.cfg worked.
gensplejs wrote: Fri Oct 17, 2025 8:31 pm So apparently downloading the keydb.cfg worked.
Use FindVUK-synchronize or KeyBD_Helper to just add new keys.
