thesot
Post
by thesot » Thu Aug 28, 2025 9:55 pm
New to backing up my movies.
I have the Back to the Future 30th Anniversary collection. First two movies (and others I've ripped) ripped no problem. Part III fails every time. I'm using a Beelink S13 mini PC with Windows 11. Some Chinese-made (I'm sure junk) external Blu-ray player (I don't own and won't be ripping any 4k or UHD stuff). Appreciate any help. Here's the log:
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '14030204928'
Error 'Scsi error - MEDIUM ERROR:DATA SYNCHRONIZATION MARK ERROR' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '14031912960'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '14031912960'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '14032238592'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '14032238592'
Failed to save title 0 to file D:/Media/Movies/Back to the Future Part III_t00.mkv
Post
by MartyMcNuts » Thu Aug 28, 2025 11:50 pm
thesot wrote: ↑Thu Aug 28, 2025 9:55 pm
Clean the disc before trying again.
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
thesot
Post
by thesot » Thu Aug 28, 2025 11:53 pm
MartyMcNuts wrote: ↑Thu Aug 28, 2025 11:50 pm
Tried. Same result.
Blyth
Post
by Blyth » Fri Aug 29, 2025 6:51 am
What did you clean the disc with? dish soap never works for me I suppose it depends what dish soap you have. What works for me is glasses cleaner
(spec glasses)
thesot
Post
by thesot » Fri Aug 29, 2025 11:59 am
Literally just a soft cloth. I didn't spray it with anything. All the disc had on it was my own fingerprints (which are definitely on other discs I've ripped). I can try some kind of glass cleaner and see.
I also just realized last night that my external drive has a 5V power input in the back. I plugged that in to a non-fast charging power block. If external power might be cause of the issue. I'll try ripping it again later tonight after having that plugged in and using some glass cleaner on the disc.
releprev
Post
by releprev » Fri Aug 29, 2025 3:01 pm
I am having the same issue. I am getting hash error on a libredrive LG and on another drive (older asus) I get a read error that the log link tells me I am in denial about my disk being bad. Works fine in my Panasonic player. I cleaned it with a microfiber and some cleaning solution this am and will give it another go. My edition comes with the UHDs too and the UHD of this film ripped fine btw so I might just have to do handbrake encode shenanigans and live with that if I can't get it to work today.
thesot
Post
by thesot » Fri Aug 29, 2025 8:15 pm
Cleaned with a microfiber cloth and some glass cleaner. Have the drive plugged into external power. Still fails about a third of the way through. Same errors.
Post
by MartyMcNuts » Sat Aug 30, 2025 6:53 am
thesot wrote: ↑Fri Aug 29, 2025 8:15 pm
Either a bad disc or a shitty drive.
Blyth
Post
by Blyth » Sat Aug 30, 2025 7:45 am
thesot wrote: ↑Fri Aug 29, 2025 11:59 am
Definitely not a good way to clean discs, get the disc nice and wet with the cleaning solution, use two microfiber cloths, one to use wet with cleaning solution and the second one to dry it off and buff away. I have had some problem discs that only ripped after a few times of cleaning.
Is it always failing at the same point? or is it random?
thesot
Post
by thesot » Sat Aug 30, 2025 2:16 pm
Blyth wrote: ↑Sat Aug 30, 2025 7:45 am
I've tried ripping it about 6 times. I'm not sure about each time, but the last two times showed the same offset number. I don't know if that means it's the same location or not.
I will note the disc appears spotless (after cleaning it) and plays totally fine in an actual Blu-ray player.
Also, just ran into a similar issue with Deadpool. Trying it a second time now.
UPDATE: wiped off the Deadpool disc and ripped fine.
thesot
Post
by thesot » Thu Sep 04, 2025 11:24 pm
Found this link:
https://www.makemkv.com/errors/read/ and saw the sticky about read errors and feel dumb for making this thread.
At any rate, that link mentions there's a way to copy the entire contents of a disc to the computer and then convert to a copy that MakeMKV can read. Not seeing that how-to anywhere. Anybody know?
Post
by MartyMcNuts » Thu Sep 04, 2025 11:51 pm
thesot wrote: ↑Thu Sep 04, 2025 11:24 pm
Found this link:
In MakeMKV use the folder option (button in top menu with an image of a folder) to backup the disc to a folder. Don't forget to check the box to decrypt the disc contents!
y3kt07
Post
by y3kt07 » Fri Sep 05, 2025 6:34 pm
I'm experiencing the exact same issue with my set. No way to read the third disc, my drive is a Pioneer.
thesot
Post
by thesot » Sun Sep 07, 2025 1:49 am
MartyMcNuts wrote: ↑Thu Sep 04, 2025 11:51 pm
