Dawson’s Creek Blu-ray Box (Region B, 2024) – MKB v81 – no SVQ dumps created
haenno
#1 Post by haenno » Fri Sep 05, 2025 3:09 pm
I’m trying to back up the new Dawson’s Creek Blu-ray Box (Region B, Sony, 2024) with my drive:
Product: BD-RE BU40N
Firmware: 1.03-MK (LibreDrive enabled)
Problem: The discs use MKB Revision 81. When I try to open them in MakeMKV, the log shows the DiscID but then fails with loads of:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '0'
No .svq dump files are generated in my data directory (only _private_data.zip and KEYDB.cfg are present).
Example:
VolumeName : Dawsons Creek S3D2
DiscID : 5E9231E06BA5DD2AF85E500344D3EE32C9454FDF
MKB Revision : 81
Because of this I cannot provide .svq files for the set. Could you please add support for these discs or advise how to force creation of valid SVQ dumps?
Many thanks in advance!
Re: Dawson’s Creek Blu-ray Box (Region B, 2024) – MKB v81 – no SVQ dumps created
#2 Post by dcoke22 » Sat Sep 20, 2025 3:34 pm
MakeMKV can decrypt AACS version 81. It is version 82 that is the problem.
