Bricked LG BU40N - Stuck in Boot Mode
ai0verflow
Post by ai0verflow »
Howdy,
I'll just get down to it, I don't know what came over me, but I used an official LG firmware update package on my BU40N, and for some reason that rendered my drive completely unusable. The disk tray won't even open, but it does show up, just with a 'BOOT' suffix. I tried to use the SDF tool to flash it again, but it doesn't recognize it as an mt1959 drive. I also tried the patched LG update tool, but it just complains about a checksum error and says the drive will return to boot mode. I haven't tried the dosflash method yet, I'm still looking into it, but I was just wondering if anyone smarter than I would have any advice for this situation. Is it still recoverable or just FUBAR now?
FINAL UPDATE:
I would really recommend RTFM instead of just trying stuff and panicking. I watched the video about using DOSFlash to recover bricked drives, and I was able to fully recover the drive. The crucial step I missed in my reply was using the data mover EXE on my rom dump to copy the drive specific data to the new MK rom. And thankfully I actually dumped the original 'broken' rom before flashing the drive, otherwise I really would have been SOL. Using that video, the drive serial number now reports properly, LiberDrive works, and am currently ripping my 4k release of Interstellar.
So, just as a lesson to people watching this trainwreck: DO NOT USE THAT LG FIRMWARE UPDATE, AND MAKE BACKUPS OF YOUR STUFF BEFORE YOU FLASH
ai0verflow
Re: Bricked LG BU40N - Stuck in Boot Mode
UPDATE:
So I was able to partially recover the drive using dosflash...I was able to flash the 1.03MK firmware with it. It now shows up in MakeMKV with LibreDrive enabled, however it will not read a disc, it behaves as if there's nothing in the drive. The serial number is also blank in MakeMKV, and I believe these two are related. I hear there's calibration data in the original firmware that probably isn't in the 1.03MK file, however I did make a backup of the stock firmware in SDF tool, and I also made a backup of the borked firmware before I flashed it in dosflash. If there's anyone that can help fully recover this thing I would be eternally grateful.
ai0verflow wrote: Fri Sep 05, 2025 2:35 am Howdy,
Try the old modified ASUS flasher and use the BU40N 1.03-MK firmware. viewtopic.php?p=70766#p70766
There is really never any need to update optical drive firmware. Updates usually only affect disc writing, not reading.
ai0verflow
I think that was the actually the one thing I didn't try, was the asus flasher. But, writing media is what spawned this whole mess. I would like to burn some 50GB dual layer discs, and I've only heard of all the lovely firmware issues with them things. I thought maybe I could use the LG update to bring it back to the original firmware in case I had issues, but I guess I really learned my lesson on that. In case you see this before my edited post, I was able to fully recover the drive using DOSFlash, though it remains to be seen how the 1.03MK firmware handles burning dual layer disks. If there's issues I'll probably just get another drive.
ai0verflow wrote: Fri Sep 05, 2025 6:46 am But, writing media is what spawned this whole mess. I would like to burn some 50GB dual layer discs, and I've only heard of all the lovely firmware issues with them things. … though it remains to be seen how the 1.03MK firmware handles burning dual layer disks. If there's issues I'll probably just get another drive.
Pioneer drives are considered pretty good for actually burning discs. Depending on where you are in the world, you might still be able to get one. Any new one you get will probably have firmware on it that's too new to rip UHDs, but it should still rip DVDs and regular blu-rays out of the box. If it is a model that supports UHDs, Mike has said that eventually it will be supported, regardless of the firmware.
ai0verflow
I’ll have to look into them, since I don’t really know the first thing about them. I’m in the US, if there’s any models you would recommend in particular, 5.25” or slim type, I’m open to that.
Wldulikesometoast
Post by Wldulikesometoast »
Hi guys, it seems I have encountered a similar problem here.
I have a verbatim 48888 (LGBU40N internals) which is only six weeks old. When I bought the drive, I followed the (excellent) guides in the forum and used SDF tool to flash the recommended 1.03 FW.
The flash went by without a hitch and the drive worked generally well for the first month. I did encounter the odd issue with one UHD disc here and a few blu ray there, some of which were resolved using isopropyl alcohol whilst others I couldn't extract (all using makemkv).
I encounted a few issues within the first two weeks and replaced the included usb C-A cable into the also provided A-C convertor with a single full spec usb C-C cable into my M4 Mac Mini. This improved ripping outcomes.
Things went down hill between weeks 4-6 when the drive started failing rips more and more, making mechanical seeking noises in the last 10-15% of a rip which often resulted in failure due to SCSI error.
It has got to the stage that I've decided to attempt to return the drive as I think it's dying. I decided I better re-flash the lg 1.05 FW and so downloaded the LG tool (you can see where this is going) and it borked 48% through the flash and now is stuck in boot mode.
I'm thinking of now following the findings here, is there any other advice anyone can share please? I've researched heavily since my cock up of flashing using the lg tool and only found this thread....
Cheers - love this place, it's a great community resource - my physical collection continues to grow!
P.S. any recommendations as to a new drive to replace this, regardless of my return attempt? Ideally I want to rip blu ray and uhd but I'm seeking a lot saying pioneer drives have a tricky firmware currently that precludes them from ripping UHD at this time....
Wldulikesometoast
One related question, does anyone have 1.05fw please?
Wldulikesometoast wrote: Tue Nov 04, 2025 9:30 pm One related question, does anyone have 1.05fw please?
No, but you can download the original LG BU40N 1.05 flasher from here:
https://www.lg.com/us/support/product/l ... A10B?tab=1
If it won't get the drive out of boot mode, you could try using the old Modified ASUS flasher (viewtopic.php?p=70766#p70766) to flash the drive with BU40N 1.03-MK or BU40N 1.04-MK. If this works, you can then use the original BU40N 1.05 flasher.
Wldulikesometoast
MartyMcNuts wrote: Tue Nov 04, 2025 11:53 pm
Hi Marty, thanks for the reply dude - really appreciate it.
I've tried the LG 1.05 flasher and get the error message 'the firmware cannot be updated because the SVC code of target drive is different with SVC code on firmware'.
I also tried using the modified Asus flasher to flash both BU40N 1.03_MK and BU40N 1.00 and both return error 'Updating failure 5'
I then booted up my mac mini and attempted to flash using the command line tool there, after much googling and reading the main forum post I came up against failures with both below commands:
./makemkvcon f -d '/IODVDServices/D3B36C63' -f /tmp/sdf.bin rawflash main -i /tmp/1.03.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Any ideas....?
Last edited by Wldulikesometoast on Thu Nov 06, 2025 11:07 pm, edited 1 time in total.
No, I am out of ideas. Might have to bin it.
Did you try contacting LG and explain that when you tried to update firmware using their provided tool, it borked the drive? Might be worth a shot.
Wldulikesometoast
MartyMcNuts wrote: Thu Nov 06, 2025 9:12 pm No, I am out of ideas. Might have to bin it.
No worries, thanks dude. I'm gonna try that tomorrow ..see what happens!
Wldulikesometoast
Any strong recommendations on a replacement drive? Ideally one I can rip uhd with and usb ...
Wldulikesometoast wrote: Thu Nov 06, 2025 9:29 pm
A Pioneer if you can manage to find one!! Extremely rare and very expensive but better than anything else! The only other drive I would suggest is a Verbatim 43888 which has a BU40N inside. I have flashed bucket loads of these without issue.
ai0verflow
Wldulikesometoast wrote: Thu Nov 06, 2025 6:10 pm
Any ideas....?
I had the exact same problem, unfortunately dosflash was the only program that would actually talk to the damn thing. Unfortunate because it requires some old pc hardware laying around and shucking the drive for a direct sata connection to it. Made even more complicated since nearly no desktops out there have a sata slimline power connector for your laptop drive. Luckily the mini pc I had laying around did.
The drive is recoverable, it’s just a matter having the right junk laying around and how much you value your time vs just buying a new drive.
