List of DVD/BluRay that haven't worked
Wasabi
Re: List of DVD/BluRay that haven't worked
#181 Post by Wasabi » Sat Oct 09, 2010 10:45 pm
All 3 discs of The Jeffersons Season Five give errors. They play fine, and they convert by muxing the VOBs with MKVMerge with no issue (I noticed doing it with MKVMerge keeps closed captions that ffdshow can decode - if this is possible with MakeMKV, I'd love to know how).
I've tried MakeMKV's native decryption, decrypting with AnyDVD first, and running the discs through DVDShrink and DVD Decrypter and still get the same errors. MakeMKV had no problems with Seasons One through Four, and so far Season Six is okay as well.
001005:0000 MakeMKV v1.6.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as ************MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at '3FI&Q85u'G@%cp?:213135251
001003:0020 DEBUG: Code 101016576 at %jPODZ{Yumy{s ~=t :29395839
001003:0020 DEBUG: Code 101016576 at %jPODZ{Yumy{s ~=t :121261727
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL ATAPI DVD RW GBIA' at offset '524288'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL ATAPI DVD RW GBIA' at offset '1048576'
001003:0020 DEBUG: Code 101016576 at %jPODZ{Yumy{s ~=t :121264579
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL ATAPI DVD RW GBIA' at offset '32768'
001003:0020 DEBUG: Code 0 at 2S/%"#:m|<ubkebp-'A:29393447
Application exited at Sat Oct 09 22:40:18 2010
setarip_old
#182 Post by setarip_old » Sat Oct 09, 2010 11:54 pm
@Wasabi
Hi!
Perhaps it has something to do with the apparent nature of the media you are trying to read/backup as .MKV...
Wasabi
#183 Post by Wasabi » Thu Oct 28, 2010 4:29 pm
Wasabi wrote:All 3 discs of The Jeffersons Season Five give errors.
This has been fixed in v1.6.2. :mrgreen:
SWRogue
#184 Post by SWRogue » Thu Aug 18, 2011 6:32 am
Here is a screen grab of the Errors I get when trying to rip the Movie of, Star Trek The Motion Picture Blu-Ray STAR_TREK_I_EU
I'm running 1.6.13 on Win7 64bit 8gig
Cannot find any options to change much, have only been trying to Rip just the Movie will try a full backup
if I can.
http://i1221.photobucket.com/albums/dd4 ... errors.png
Error / Text Buffer fills with all of this.
Top most line.
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 21925466112, attempting to work around
Then on and on. till.
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 22129600512, attempting to work around
Failed to save title 0 to file D:/BDRip/title00.mkv
0 titles saved, 1 failed
1st Edit
MakeMKV v1.6.13 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Stefan/MakeMKV_log.txt
Backing up disc into folder "D:\BDRip/backup/STAR_TREK_I_EU"
DEBUG: Code 0 at 3-Q%6pVnz3f+@$gvWnAB:213142542
Backup failed
Backing up disc into folder "F:\BDRip/backup/STAR_TREK_I_EU"
But its still trying to continue.
2nd Edit
Hash check failed for file /BDMV/STREAM/00004.m2ts at offset 21695686656, file is corrupt.
Hash check failed for file /BDMV/STREAM/00004.m2ts at offset 21712594944, file is corrupt.
Hash check failed for file /BDMV/STREAM/00004.m2ts at offset 22125078528, file is corrupt.
Hash check failed for file /BDMV/STREAM/00004.m2ts at offset 22129600512, file is corrupt.
Hash check failed for file /BDMV/STREAM/00004.m2ts at offset 22143559680, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00004.m2ts.
BTW the Disk is Clean.
3rd Edit
Hash check for /BDMV/STREAM/00004.m2ts : 0.02% corrupt, 99.97% correct, 99.99% checked.
Backup done but 1 files failed hash check
#185 Post by mike admin » Thu Aug 18, 2011 3:41 pm
Hashcheck errors always mean that either the disc or drive is bad.
SWRogue
#186 Post by SWRogue » Thu Aug 18, 2011 11:52 pm
Ok well this is a new System but I have ripped say 10 Blu-Rays before this one so I think I maybe the Disk.
DONIMOTO
#187 Post by DONIMOTO » Sun Jan 22, 2012 8:18 am
The Professionals (1966) failed at same location with two different originals. "0 files saved"
ottawaxblade
#188 Post by ottawaxblade » Thu Jan 26, 2012 5:13 am
I am having trouble ripping the bluray called The Switch (2010/11 Jennifer Aniston) to mkv.
I've been able to rip well over 60 of my blurays with no issues up until this one. Rips fine with no errors mentioned. Audio plays fine, video seems all choppy almost like pause/play is being hit repeatedly. Disc plays fine in pioneer bd206 drive as well as my stand alone bluray player. I've also cleaned the disc, no signs of scratches.
Latest copy of makemkv is being used (1.7.0) running Windows 7 Pro 64bit.
attempted this disc 4 times now with same results :(
setarip_old
#189 Post by setarip_old » Thu Jan 26, 2012 6:23 pm
@ottawaxblade
Hi!
After this problem occurred four times, did you try re-ripping another Blu-ray disc that you previously ripped without any playback problems? If not, try this now - If the same problem shows up, your drive is very likely the cause of your problem...
ottawaxblade
#190 Post by ottawaxblade » Fri Jan 27, 2012 1:22 am
setarip_old wrote:@ottawaxblade
Hi!
@setarip_old
Thanks for the suggestion, I'm in the process of ripping something that I've ripped in the past and see what happens. I'll report shortly.
ottawaxblade
#191 Post by ottawaxblade » Fri Jan 27, 2012 2:05 am
So i've re-ripped something that I've ripped before that I knew works and replayed the new rip and it works flawlessly so i'm thankful to know that my drive is still working :)
Now as to why the movie The Switch wont rip properly is a mystery to me. Anyone else try ripping this movie?
setarip_old
#192 Post by setarip_old » Fri Jan 27, 2012 2:16 am
Since we've determined that the drive apears to be performing properly, I'd speculate that it's a poorly manufactured disc. I'd suggest you return it to the place of purchase in exchange for a new replacement...
BlackDragon24
#193 Post by BlackDragon24 » Sat Jan 28, 2012 1:55 pm
ottawaxblade wrote:So i've re-ripped something that I've ripped before that I knew works and replayed the new rip and it works flawlessly so i'm thankful to know that my drive is still working :)
I've got a pioneer bdr-206. I'll see if I can't get a copy and try to rip it this weekend.
Opentoe
#194 Post by Opentoe » Sun Jan 29, 2012 10:07 am
I had trouble ripping the BD called "REAL STEEL". Actually it did rup the first 2 main titles, but then errored out after that. I think there was one or two more titles left.
raddoc
#195 Post by raddoc » Sun Jul 13, 2014 8:06 pm
Hi
Trying to make a copy of TinkerBell Great Fairy Rescue for my kids. It get about 90% done then fails. I increased the I/O from 5->20 in preferences. Disc is clean. Any suggestions?
MakeMKV v1.8.11 darwin(x86-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.00d" opened in OS access mode.
File 00499.mpls was added as title #0
File 00253.mpls was added as title #1
Title #00020.mpls has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00308.mpls was added as title #2
File 00320.mpls was added as title #3
Title #00236.mpls has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00214.mpls was added as title #4
Title #00215.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00217.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.mpls has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00800.mpls is equal to title 00499.mpls and was skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00067.m2ts was added as title #5
Title #00068.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00378.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00416.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00421.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00422.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00423.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00424.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00425.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00426.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00427.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00428.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00429.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00430.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00431.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00432.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00433.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00434.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00435.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00436.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00437.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00438.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00439.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00440.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00441.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00442.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00443.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00444.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00445.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00446.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00447.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00448.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00453.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00454.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00455.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00456.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00457.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00458.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00459.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00460.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00461.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00463.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00464.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00465.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00467.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00468.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00469.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00470.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00471.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00472.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00473.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00474.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00475.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00476.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00477.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00478.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00479.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00480.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00481.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00482.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00483.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00484.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00485.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00486.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00487.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00488.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00489.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00490.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00491.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00492.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00493.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00494.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00495.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00496.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00497.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00498.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00499.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00500.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00512.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00515.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00518.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00521.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00522.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00523.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00524.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00525.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00526.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00529.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00530.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00531.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00532.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00533.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00534.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00535.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00536.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00537.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00538.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00539.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00540.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00541.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00542.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00543.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00544.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00545.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00546.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00547.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00548.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00549.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00550.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00551.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00552.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00553.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00554.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00555.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00556.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00557.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00558.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00559.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00560.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00561.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00562.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00563.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00564.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00565.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00566.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00567.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00568.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00569.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00572.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00573.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00574.m2ts was added as title #6
Title #00576.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00577.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00578.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00579.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00580.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00581.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00582.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00583.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00584.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00585.m2ts was added as title #7
Title #00586.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00587.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00588.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00589.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00590.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00591.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00592.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00593.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00594.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00595.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00596.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00597.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00598.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00599.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00602.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00603.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00604.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00605.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00606.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00607.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00608.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00610.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00611.m2ts was added as title #8
File 00612.m2ts was added as title #9
Title #00613.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00614.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00615.m2ts was added as title #10
Title #00616.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00617.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00618.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00619.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00620.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00621.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00622.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00623.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00624.m2ts has length of 97 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00625.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00626.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00627.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00417.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00418.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Lacie Raid/turbo
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00066.m2ts' at offset '20759248896'
Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00066.m2ts' at offset '20759248896'
Failed to save title 0 to file /Volumes/Lacie Raid/turbo/Tinker_Bell_And_The_Great_Fairy_Rescue_t00.mkv
