Makemkv is super slow on version 1.18.1
Tiavor
Post by Tiavor » Sat Aug 23, 2025 8:01 am
When ripping a disc it gets stuck for 4 to 5 minutes on "Analyzing seamless segments" and then continues for around 30s to 1min saving the mkv and getting stuck for 5 minutes doing nothing, etc.pp. While it's stuck analyzing, all IO to all drives is frozen. opening task manager doesn't even show any hard drives during those 5 minutes. opening explorer immediately freezes it.
It works totally fine on continuous 2x speed with any 1.17 version (last tested 1.17.9)
Tested multiple BR discs on both versions with the same result.
what takes 1 hour in 1.17, now takes 6 hours in 1.18
System:
Windows 10 Pro build 19045
Mobo: Gigabyte X570S UD
CPU: AMD Ryzen 7 5800X3D
RAM: 2x16GB DDR4-3200 Crucial/Micron
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8A10
Firmware version: 1.14
dyoung
Re: Makemkv is super slow on version 1.18.1
Post by dyoung » Wed Sep 03, 2025 8:28 pm
I am not experiencing that issue, nor did I see any other reports of other people experiencing it which I would guess there would be plenty by now.
I occasionally experience issues with MakeMKV behaving similar to how you describe, but it causes no other issues for me.
I solve the issue with MakeMKV by either restarting MakeMKV and opening/closing my disc drive or rebooting my PC.
Although, I completely forgot I intended to post a recent issue which I think was only solved when I hard-killed the power to my PC.
To clarify, it was MakeMKV being unable to read discs and being VERY slow at trying, but I think the drive itself was unable to read discs, with no other issues you describe.
The solution was to not reboot but power off the PC then switch off the power supply.
First & only time (thus far) I needed to physically disconnect power to fix an issue such as this, but could be worth an attempt.
Post by dcoke22 » Thu Sep 04, 2025 4:13 pm
Sometimes when my optical drive misbehaves I find the situation is improved if I power cycle the drive. In my case, since the drives are in powered external enclosures, it is as easy as powering off the enclosure, waiting a moment and turning it back on. If the drives are inside a machine, you'll have to power down the machine and switch off or unplug the power supply. If the drive is USB powered then unplugging it, waiting a moment, and plugging it back into high power USB ports will do the trick.
Do things still run slowly if the drive is power cycled?
Tiavor
Post by Tiavor » Thu Sep 11, 2025 9:16 pm
I restarted my system several times, I tried plugging in the drive at different points, before starting the program, after, inserting disc at different points etc.
I switched back and forth between versions. It's definitely always slow on 1.18 and always faster on 1.17. no matter what I do.
lojj09fr
Post by lojj09fr » Sat Sep 20, 2025 5:41 pm
Same thing for me, I uninstall the 1.18 version and install the v.17.8 but makemkv remains too slow and unusable.
