LibreDrive for Pioneer drives
timkur
#1606 Post by timkur » Thu Sep 04, 2025 3:01 am
Hey folks,
Just received this Pioneer drive. I think the firmware is old enough to cross flash it... are there simple instructions to flash these?
Tim
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: CLDL054812WL
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 82
#1607 Post by Billycar11 » Thu Sep 04, 2025 3:12 am
timkur wrote: Thu Sep 04, 2025 3:01 am Hey folks,
Tim
Revision: 1.02
yes it can be flashed just email me for the flasher see below
p1xel8ted
#1608 Post by p1xel8ted » Thu Sep 04, 2025 10:02 am
OS device name: L:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Highest AACS version: 61
Firmware version: ID05
Think I'm SOL
dump_FW_CD2860D1B8E81B285CDE.tgz
(275 Bytes) Downloaded 245 times
#1609 Post by MartyMcNuts » Thu Sep 04, 2025 10:47 am
p1xel8ted wrote: Thu Sep 04, 2025 10:02 am Drive Information
OS device name: L:
Revision: 1.03
Think I'm SOL
Yep, you will have to wait for future support.
christrati
#1610 Post by christrati » Thu Sep 04, 2025 4:07 pm
Been using an LG drive a while, and wanting to have a backup. Just purchased an ASUS BW-16D1X-U, and looks like it has a Pioneer drive. I see a lot of the flash guides are for the LG and the Pioneer drive it depends on the firmware etc. So adding my drive to the list to see if there is a firmware or unlocking tool to allow it to read UHD discs and fully usable in MakeMKV.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127851WL
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: ID76
#1611 Post by Coopervid » Thu Sep 04, 2025 4:16 pm
christrati wrote: Thu Sep 04, 2025 4:07 pm Been using an LG drive a while, and wanting to have a backup. Just purchased an ASUS BW-16D1X-U, and looks like it has a Pioneer drive. I see a lot of the flash guides are for the LG and the Pioneer drive it depends on the firmware etc. So adding my drive to the list to see if there is a firmware or unlocking tool to allow it to read UHD discs and fully usable in MakeMKV.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM is coming.
Thesappster
#1612 Post by Thesappster » Fri Sep 05, 2025 12:19 am
I just bought the ASUS BW-16D1X-U as well. Hoping mine can be flashed for UHD. Any and all help is greatly appreciated.
OS device name: /dev/rdisk11
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 63
Heelmaybe
#1613 Post by Heelmaybe » Fri Sep 05, 2025 2:00 am
Borrowing the format from the last person.
I just bought the PIONEER BDR-XS07U. Hoping mine can be flashed for UHD. Any and all help is greatly appreciated.
Revision: 1.04
Serial number:
Firmware date: 2024-10-09
christrati
#1614 Post by christrati » Fri Sep 05, 2025 2:34 am
Got a PM from @Coopervid, pretty quick after posting this. Got the appropriate firmware and was able to flash my drive. Thanks for the directions!
Chris
#1615 Post by Billycar11 » Fri Sep 05, 2025 7:39 am
Thesappster wrote: Fri Sep 05, 2025 12:19 am I just bought the ASUS BW-16D1X-U as well. Hoping mine can be flashed for UHD. Any and all help is greatly appreciated.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
email me that drive info see below
#1616 Post by Coopervid » Fri Sep 05, 2025 10:20 am
Heelmaybe wrote: Fri Sep 05, 2025 2:00 am Borrowing the format from the last person.
Revision: 1.04
Serial number:
Firmware is too new. You have to wait until Mike has a solution.
Thesappster
#1617 Post by Thesappster » Fri Sep 05, 2025 5:41 pm
Much appreciated.
Heelmaybe
#1618 Post by Heelmaybe » Sat Sep 06, 2025 12:21 am
Coopervid wrote: Fri Sep 05, 2025 10:20 am
Revision: 1.04
Serial number:
Is there other drives that I can buy that are not as expensive as the pioneers that are guaranteed to work out of the box?
#1619 Post by Billycar11 » Sat Sep 06, 2025 12:31 am
Heelmaybe wrote: Sat Sep 06, 2025 12:21 am
out of the box is dead and is not coming back anytime soon.
lg drives out of the box died in 2017
pioneer out of the box died in 2022 the same year support was added for them
no new drive will work out of the box
personforsure
#1620 Post by personforsure » Sat Sep 06, 2025 7:32 pm
Hi. I have been buying and returning external blue ray rippers lately, trying to find one that would work to read and rip 4k UHD. This is the last one I got and it has firmware from 12/2022. I did not update this, this was fresh out of the box. I did not download a Pioneer utility to update firmware. When I looked at the guide and many posts, it has been written as 'after 12/2022'. Is this the bad firmware? I got this from amazon and it was listed as BD-RW BDR-XD08S, the box matches this (of course this could be repackaged). Does anyone have advice on if this is supported out of the box? Its not playing 4kUHD blue rays, only regular blu rays.
I thought I was getting this model (from the guide: drives that Currently work are:
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins)
Product: BD-RW BDR-XD08
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 58
Drive platform: Pioneer RS9330
Firmware version: GENE
