BD Drive Recommendations
jaark
Post by jaark »
This may be a silly question, but does MakeMKV work with any BD drive?
My current drive has a modified Firmware as the ripping tools I was using at the time needed the drive to not bother with device/host authentication. This drive has now given up the ghost.
DOes anyone have any suggestions for a reasonable internal SATA BD drive?
TIA
crowfax
Re: BD Drive Recommendations
Post by crowfax »
Yup, it should work with any drive.
Most people seem to buy the internal LG drives. All my machines are laptops, so I only use external drives myself.
jaark
Post by jaark »
Thanks guys, my old one is LG. I was needlessly concerned that I couldn't find modded firmware for newer ones :)
setarip_old
Post by setarip_old »
@jaark
Hi!
With MakeMKV fully capable of doing Full Disc Blu-ray backups, I'd ask you why you feel you still need to modify your drive(s)...
jaark
Post by jaark »
setarip_old wrote:With MakeMKV fully capable of doing Full Disc Blu-ray backups, I'd ask you why you feel you still need to modify your drive(s)...
I don't now.
Before MakeMKV came along, there were two choices that I was aware of - AnyDVD or a modified firmware. It was accepted and common knowledge that the other software didn't have the correct keys to authenticate to the drive. As I've never used MakeMVK without a modified firmware, I've never put any thought to whether it needed one or not. As I now need a new drive, I realised I had better find out before potentially throwing my money away. Reading through the website and FAQ didn't answer the question one way or the other.
setarip_old
I don't now.
I'm glad to hear that you understand that.
(Presently, there are three major choices for Blu-ray copying: MakeMKV, DVDFab, and AnyDVDHD)
