Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
crossbone
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Post by crossbone »
Hi there, just undusted my old drive and would also like to digitalize some of my UHD BluRay Collection. Can someone kindly provide the firmware? Here are my drive details:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer:
Firmware-Datum: 2016-04-25
Highest AACS version: 57
Drive platform: RS8600
Firmware version: 1.34/ID43
Cheers!
crossbone wrote: Wed Sep 03, 2025 2:04 pm Hi there, just undusted my old drive and would also like to digitalize some of my UHD BluRay Collection. Can someone kindly provide the firmware? Here are my drive details:
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.34
Serienummer:
Cheers!
PM sent.
driveripper9000
Post by driveripper9000 »
Hello! Got this drive off of eBay and was also looking to digitize my old UHD discs. This is the drive information in makeMKV. Help is greatly appreciated!
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.31
Serial number: PADL006557CN
Firmware date: 2015-05-25
Highest AACS version: 47
Firmware version: 1.31/ID43
sugizoyuu
Post by sugizoyuu »
Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
Here is the information of the drive.
OS device name: I:
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Thank you so much.
sugizoyuu wrote: Sat Nov 08, 2025 3:33 pm Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
OS device name: I:
Revision: 1.34
Serial number:
Thank you so much.
PM sent.
driveripper9000
Coopervid wrote: Sat Nov 08, 2025 7:47 pm
OS device name: I:
Revision: 1.34
Serial number:
Thank you so much.
PM sent.
Is it possible to flash my drive? I appreciate the help.
Thank you.
sugizoyuu
Post by sugizoyuu »
Hi Coopervid,
Just wanted to say a huge thanks! Thanks to your help, my Blu-ray drive is now working perfectly with UHD discs.
Really appreciate your guidance and patience — it made the whole process much easier.
Thanks again for taking the time to help me out!
Cheers,
sugizoyuu
OS device name: I:
Revision: 1.34
Serial number:
Thank you so much.
PM sent.
ryanteck
Post by ryanteck »
Another new user, Wondering if my Pioneer can be flashed.
OS device name: G:
Revision: 1.34
Serial number:
Highest AACS version: 68
driveripper9000 wrote: Fri Oct 31, 2025 1:07 am Hello! Got this drive off of eBay and was also looking to digitize my old UHD discs. This is the drive information in makeMKV. Help is greatly appreciated!
Revision: 1.31
PM sent.
ryanteck wrote: Sat Nov 08, 2025 10:56 pm Another new user, Wondering if my Pioneer can be flashed.
OS device name: G:
Revision: 1.34
Serial number:
PM sent.
ben79968
Post by ben79968 »
I just got a Pioneer BDR-S09XLT with FW 1.30
Can it be flashed to support UHD discs, or should I just update to FW 1.54?(latest before 2022/12)
OS device name: H:
Revision: 1.30
Serial number:
Firmware date: 2014-12-05
Highest AACS version: 77
Firmware version: 1.30/ID43
ben79968 wrote: Sat Nov 15, 2025 12:39 pm I just got a Pioneer BDR-S09XLT with FW 1.30
OS device name: H:
Revision: 1.30
Serial number:
PM is coming.
ben79968
Post by ben79968 »
It flashed successfully! Thanks!
I'll try it when I get a UHD disk.
I just want to get newer firmware for writing disks.
Coopervid wrote: Sat Nov 15, 2025 1:05 pm
OS device name: H:
Revision: 1.30
Serial number:
PM is coming.
Now you got everything... :D
penguinparatrooper
Post by penguinparatrooper »
OS device name: /dev/sr0
Revision: 1.34
Serial number:
Highest AACS version: 65
Coopervid, please PM me for firmware update info. I have been flashing LG drives just fine but these Pioneers are a bit tricky =)
