Recommended Optical Drive - Sep 2025
newsoftheworld
Post by newsoftheworld » Tue Sep 02, 2025 5:29 pm
Hi All,
New to the forum. Reading through this forum it seems like it's easy to make a mistake when buying an optical drive as some drives can be upgraded to UHD and some can't. with this in mind I had been considering the options below.
option 1: ASUS BW-16D1HT drive inside a Vantec NexStar DX2 USB 3.0 caddy
option 2: ASUS BW-16D1X-U External Drive USB 3.0
I've had a slimline drive in the past and enjoyed it but was thinking I'm needing more a workhorse that will last a long time and not only be able to facilitate ripping of UHD discs but also be accurate and not fussy about reading second hand cd's.
I welcome your thoughts and advice. Thank you
flojo
Re: Recommended Optical Drive - Sep 2025
Post by flojo » Tue Sep 02, 2025 7:16 pm
...not fussy about reading second hand cd's.
For UHD you should try to get a Pioneer and see if you can get it flashed to Libre.
CDs are a different game and none of these UHD drives are great at ripping CD. Some will read from the cache, some won't read CD-TEXT, some wont' read subchannel data. Although you don't really need all of that if all you care about is the CDDA and use a verification database like cuetools or whatever (although if it's a really, really old CD you'd want subchannel data read).
newsoftheworld
Post by newsoftheworld » Tue Sep 02, 2025 8:14 pm
Hi Flojo,
thank you for your reply. I currently have a Pioneer BDR-XD07TS (Mfd Dec 2020) which I mainly have used for ripping CD's but also some DVD's and Blu-rays It has recently started playing up not reading some cd's and and after cleaning the lens it works sometimes but most times behaves flakey. I had thought that many Pioneer drives weren't able to be upgraded to Libre, so have been looking to get a more reliable replacement that can be flashed to libre but don't want to buy the wrong thing.
OS device name: /dev/rdisk7
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TLDx
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest
AACS version: 75
Drive platform: Pioneer RS8D30
Firmware version: GENE
Post by Billycar11 » Tue Sep 02, 2025 9:19 pm
Hi Flojo,
Revision: 1.06
Serial number: TLDx
Highest
AACS version: 75
To bad you updated the firmware pioneers are the best
Lizard
Post by Lizard » Wed Sep 03, 2025 4:36 am
Hi Flojo,
Revision: 1.06
Serial number: TLDx
Highest
AACS version: 75
A lot of people are liking the LG WH16NS40 or the BH16NS40 that you can cross flash.
It should hold up better being an internal drive too.
$95 us over at CDW.com is not a bad price either. $120 amazon.
You can read about people having success over here:
viewtopic.php?t=20054&start=15
—Lizard
newsoftheworld
Post by newsoftheworld » Wed Sep 03, 2025 7:41 am
[/quote]
Hi Billycar11,
Thank you for your reply. I flashed it myself, my mistake, thinking I need to stay on top of all updates. I hadn't realised that the firmware couldn't be erased and another firmware installed. Most things on a computer can be erased and you can start again. I'll be more cautious with firmware going forwards. So, I may purchase either of the the following new off Amazon so that I get 1 or 2 years warranty. Would you be able to advise me if this is a good idea to enable me to rip UHD or do I need to buy old stock with old firmware?
Best Wishes
Post by Billycar11 » Wed Sep 03, 2025 8:19 am
Best Wishes
would never recommend a lg/asus drive again
pioneer only now
get a 212v or dbk
Lizard
Post by Lizard » Thu Sep 04, 2025 9:06 pm
Best Wishes
pioneer only now
get a 212v or dbk
Thanks Billycar11, good to know.
While significantly more expensive ($160/$190 US), I wholeheartedly agree with Billycar11. Especially since newsoftheworld brings up warranty as a concern. (hence the lifespan and durability being a larger factor)
Pioneer BDR-212V
Pioneer BDR-212BDK
—Lizard
newsoftheworld
Post by newsoftheworld » Fri Sep 05, 2025 7:24 am
[/quote]
Pioneer BDR-212V
Pioneer BDR-212BDK
—Lizard
[/quote]
Thank you Lizard and Billycar11 for your thoughts. I live in the UK and I've been trying to find these drives above new and haven't been able to source a reputable supplier to buy these new. Either they're astronomically expensive because they're so rare or you can buy them second hand but still go for the price of a new LG or Asus drive.
Does anyone (who is no doubt more experienced shopper of these drives than me) know where I can buy them new for a reasonable price delivered to the UK?
Thank you
Post by dcoke22 » Fri Sep 05, 2025 1:33 pm
Asmcom is seller on this forum that services the UK. (https://forum.makemkv.com/forum/viewtopic.php?f=20&t=19387) Unfortunately, they're closed at the moment as Asmcom has had some health difficulties. I don't know what their stock will be when they reopen or what their prices will be.
In any case, while you're looking for a BDR-212 elsewhere, it is worth monitoring for when Asmcom re-opens the shop. They'll undoubtedly modify the first post on their seller thread when they do.
newsoftheworld
Post by newsoftheworld » Fri Sep 05, 2025 5:16 pm
Thanks dcoke22,
Good advice. I've posted a message on the link you posted and will wait until Asmcom is open again. Best wishes.
outlier
Post by outlier » Sat Sep 06, 2025 1:12 am
If this video is to be believed then nobody makes optical drives anymore (both Pioneer and LG stopped this year), so get what you can find.
I'm just not sure I believe it yet. I thought that Pioneer sold off their business, so presumably that acquiring company ("Shanxi Lightchain") will eventually start/resume operation--it wouldn't make sense for them to buy it and do nothing with it. I suppose they could make drives for other purposes besides PCs.
Post by Billycar11 » Sat Sep 06, 2025 2:43 am
we contacted them they said they bough them only for the laser patents.
will that change when they see the demand for drives maybe but who knows
tommik128
Post by tommik128 » Sun Sep 28, 2025 5:22 pm
I bought another ASUS BW-16D1HT (retail version) two weeks ago and manufacturing date is May 2025. Have they stopped or not? That is the question these days...
Post by Billycar11 » Sun Sep 28, 2025 11:13 pm
Pioneer stopped October 2024
LG is still going but rumored to stop soon
