Please check if it's possible to remove the AACS from this Blu-ray Disc.
noe1002
Post by noe1002 »
https://drive.google.com/file/d/18IGcGK ... sp=sharing
Re: Please check if it's possible to remove the AACS from this Blu-ray Disc.
noe1002 wrote: Tue Sep 02, 2025 1:44 am Please check if it's possible to remove the AACS from this Blu-ray Disc.
Did you follow the correct process and email the dump file to svq@makemkv.com?? If not, please do so, otherwise it won't get added to MakeMKV's hashed keys database.
Also, you should really include the complete dump file name in your post so it can be quickly and easily identified.
