Please check if it's possible to remove the AACS from this Blu-ray Disc.
https://drive.google.com/file/d/18IGcGK ... sp=sharing
noe1002
Re: Please check if it's possible to remove the AACS from this Blu-ray Disc.
Did you follow the correct process and email the dump file to svq@makemkv.com?? If not, please do so, otherwise it won't get added to MakeMKV's hashed keys database.noe1002 wrote: Tue Sep 02, 2025 1:44 am Please check if it's possible to remove the AACS from this Blu-ray Disc.
Also, you should really include the complete dump file name in your post so it can be quickly and easily identified.
