Hello all. This DVD is my first time trying MakeMKV and I have run into a little bit of a hiccup. The dvd will re-encode all the way through but at the end I get an error saying that it failed. I've read a couple of the threads and figured to upload a testdump which I uploaded to my Google Docs. I read another thread and it said to try to save the mkv without any audio tracks and I did and it saved perfectly. So I believe I have found the problem I am just looking for a solution now. Thanks for any help.
edit: attached a log just in case.
Rage Against The Machine Error
JAGDrummer
- MakeMKV_log.txt
- (793.62 KiB) Downloaded 512 times
JAGDrummer
Re: Rage Against The Machine Error
I'm confused. Have I tried using a different DVD to try to make a MKV of this DVD? If you mean, have I tried to see if other DVDs will encode properly, yes I have and yes they do.flogger123 wrote:Have you tried using a different DVD on this? Usually it makes a difference.
