Rip fails on Aladdin Platinum Edition
am4c130d
Post by am4c130d » Tue Dec 27, 2011 9:56 pm
When ripping Aladdin Platinum Edition the rip stops/fails at 1691MB using 1.6.16 and 1.7.0 on Linux (LMDE).
The DVD plays fine on XBMC and MythTV, I can also rip the track using DVD::RIP, and can ISO dump the DVD - so suspect that the DVD is fine.
Snippets from the debug log
001003:0020 DEBUG: Code 26 at )%g?@J`{s7?,gR3[Z'X:29398622
RH=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
SP=PMHUAAOkDAAACAAAAAAQAAAAAAAA=
001003:0020 DEBUG: Code 149 at )%g?@J`{s7?,gR3[Z'X:213135067
001003:0020 DEBUG: Code 8 at )%g?@J`{s7?,gR3[Z'X:213135090
FS ID=V_MPEG2 C=162
TI=ZeNpjZICAtVeXMzEQAQ4c2wxWNw2Nz4xDvUPnVDgbpPACkHjAyMAQygyhDUoZGF4yQ+QYWBD6AOlqDR8=
001003:0020 DEBUG: Code 0 at g>"bhI#yq187HE\m>x`|m:213134216
AV sync issues in /home/alan/Videos/Aladdin/title08.mkv
AV sync in 2,3 at 1:02:26.048 (352ms) : audio gap - 11 missing frame(s)
AV sync in 1 at 1:02:25.856 (416ms) : audio gap - 13 missing frame(s)
AV sync in 1 at 1:02:26.304 (32ms) : audio gap - 1 missing frame(s)
005003:0000 Failed to save title 8 to file /home/alan/Videos/Aladdin/title08.mkv
Between the two are long binary strings - last one starts C_00161=. The log is attached as well.
Alan
MakeMKV_log.txt
(588.66 KiB) Downloaded 814 times
Re: Rip fails on Aladdin Platinum Edition
Post by mike admin » Tue Jan 10, 2012 7:49 am
A disc mastering error, workaround should be added in the next version.
Post by mike admin » Tue Jan 24, 2012 6:46 am
Please try this workaround - download attached file and place it into "MakeMKV data directory". Please post the result here. This workaround should work with any version after 1.6.16 .
reord-alladin.txt
(128 Bytes) Downloaded 880 times
am4c130d
Post by am4c130d » Thu Feb 02, 2012 12:03 am
The rip failed with V1.7.1 without the file in my "makemkv data directory". Once that was installed, it worked - thank you. At the same point 1691M it was previously failing, the following were posted to the log
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2277300224, attempting to work around
AV synchronization issues were found in file '/home/alan/Videos/Aladdin/title08.mkv' (title #9)
AV sync issue in stream 1 at 1:02:25.856 with duration of 416ms : audio gap - 13 missing frame(s)
AV sync issue in stream 1 at 1:02:26.304 with duration of 32ms : audio gap - 1 missing frame(s)
I didn't log the debug messages, let me know if you want those.
And thank you again!
cablecoder
Post by cablecoder » Fri Apr 20, 2012 3:21 pm
I'm running v1.7.4 with the reord-alladin.txt file in the "makemkv data directory" and the rip is still failing for me.
Here is the MakeMKV window output and I'm attaching the debug log file:
MakeMKV v1.7.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Tony/MakeMKV_log.txt
Title #0 has length of 278 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #1 has length of 48 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #2 has length of 84 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #3 has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #4 has length of 124 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #5 has length of 109 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #6 has length of 116 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #7 has length of 33 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #8 has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #9 has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 10-end were skipped due to cell commands (structure protection?)
Title #10 was added (9 cell(s), 0:11:29)
Title #11 has length of 240 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #12 has length of 144 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #13 has length of 236 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #14 has length of 225 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 9-end were skipped due to cell commands (structure protection?)
Title #15 was added (8 cell(s), 0:14:01)
Title #16 has length of 4 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #17 has length of 6 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #18 has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 34-end were skipped due to cell commands (structure protection?)
Title #19 was added (33 cell(s), 1:30:03)
Title #20 was added (5 cell(s), 0:11:31)
Title #21 has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #22 has length of 134 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #23 has length of 147 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #24 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #25 has length of 160 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #27 has length of 19 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #28 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #29 has length of 13 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #30 has length of 3 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #32 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #33 has length of 174 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #34 has length of 347 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #35 has length of 141 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #36 has length of 202 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #37 has length of 228 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #38 has length of 253 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #39 has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #40 has length of 254 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #41 has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/2 has length of 41 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/3 has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/1 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/2 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/3 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/4 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/5 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #45 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #47 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #48 has length of 36 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #49 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #50 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory G:/
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062245888, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062247936, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062249984, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062252032, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062254080, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062256128, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062258176, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062260224, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062262272, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062264320, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062266368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062268416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062270464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062272512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062274560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062276608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062278656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062280704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062282752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062735360, attempting to work around
AV synchronization issues were found in file 'G://title02.mkv' (title #3)
AV sync issue in stream 1 at 0:56:32.704 with duration of 64ms : audio gap - 2 missing frame(s)
AV sync issue in stream 1 at 0:56:32.800 with duration of 32ms : audio gap - 1 missing frame(s)
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276538368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276540416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276542464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276544512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276546560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276548608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276550656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276552704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276554752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276556800, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276558848, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276560896, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276562944, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276564992, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276567040, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276569088, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276571136, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276573184, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276575232, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276577280, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276579328, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276581376, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276583424, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276585472, attempting to work around
DEBUG: Code 27 at |*&l00^yEF{/2wMW.D=:121266856
DEBUG: Code 149 at |*&l00^yEF{/2wMW.D=:29399036
DEBUG: Code 10 at |*&l00^yEF{/2wMW.D=:213135389
DEBUG: Code 0 at SPT>#N;twF^Jnfq+hJ#q2:29397955
AV sync issue in stream 1 at 1:02:25.952 with duration of 192ms : audio gap - 6 missing frame(s)
Failed to save title 2 to file G://title02.mkv
0 titles saved, 1 failed
Any help would be greatly appreciated.
-T
MakeMKV_log.txt
(596.28 KiB) Downloaded 676 times
crowfax
Post by crowfax » Fri Apr 20, 2012 3:24 pm
Dirty / Damaged / Poorly Manufactured disc.
Swap it for a new one.
SLAZZ
Post by SLAZZ » Wed Mar 12, 2014 8:57 pm
Aladdin Platinum Edition failed for me at the same place:
So something is obvously wrong here. It is highly unlikely the dwo different disks would fail at the exact same place... The disks looks clean anyway... [and I have make mkv having no problem with reading/copying very dirty/scratched disks]...
I hope somebody could look into it, please.
Post by mike admin » Sun Mar 16, 2014 9:07 am
Please post the full log from the latest version.
the_limper
Post by the_limper » Sat Apr 05, 2014 4:03 am
I am seeing the same issue.
Pertinent info:
MakeMKV v1.8.9 [win(x64-release)]
I have included the full log from an attempt - I left all titles checked even though the main feature is title 8 - this is the title that is failing. (I would attach it but the board gave me a attachment quota error)
Please note that the DVD plays fine in VLC.
Title #1 was added (8 cell(s), 0:04:32)
Title #2 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #5 was added (1 cell(s), 0:02:03)
Title #6 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #12 was added (2 cell(s), 0:03:59)
Title #13 was added (2 cell(s), 0:02:23)
Title #14 was added (2 cell(s), 0:03:55)
Title #15 was added (2 cell(s), 0:03:44)
Title #16 was added (8 cell(s), 0:14:01)
Title #17 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (33 cell(s), 1:30:03)
Title #22 has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 was added (1 cell(s), 0:02:14)
Title #24 was added (1 cell(s), 0:02:27)
Title #25 was added (1 cell(s), 0:02:52)
Title #26 was added (1 cell(s), 0:02:39)
Title #28 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 was added (2 cell(s), 0:02:52)
Title #34 was added (2 cell(s), 0:02:53)
Cells 5-end were skipped due to cell commands (structure protection?)
Title #35 was added (4 cell(s), 0:05:45)
Title #36 was added (1 cell(s), 0:02:20)
Title #37 was added (1 cell(s), 0:03:22)
Title #38 was added (1 cell(s), 0:03:48)
Title #39 was added (1 cell(s), 0:04:10)
Title #40 was added (1 cell(s), 0:02:22)
Title #41 was added (1 cell(s), 0:04:14)
Title #42 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 21 titles into directory M:/Media/video/ripped_dvd/Video
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062721024, attempting to work around
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title07.mkv' (title #8)
AV sync issue in stream 4,5 at 0:56:32.800 with duration of 160ms : audio gap - 5 missing frame(s)
AV sync issue in stream 2,3 at 0:56:32.704 with duration of 96ms : audio gap - 3 missing frame(s)
Failed to save title 7 to file M:/Media/video/ripped_dvd/Video/title07.mkv
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title08.mkv' (title #9)
AV sync issue in stream 4,5 at 0:00:00.005 with duration of 128ms : 4 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.005 with duration of 256ms : 8 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.005 with duration of 224ms : 7 early frame(s) dropped at start
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title09.mkv' (title #10)
AV sync issue in stream 4,5 at 0:00:00.011 with duration of 128ms : 4 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.011 with duration of 256ms : 8 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.011 with duration of 224ms : 7 early frame(s) dropped at start
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title10.mkv' (title #11)
AV sync issue in stream 4,5 at 0:00:00.014 with duration of 160ms : 5 early frame(s) dropped at start
AV sync issue in stream 1,2,3 at 0:00:00.014 with duration of 256ms : 8 early frame(s) dropped at start
Track #9 turned out to be empty and was removed from output file
Track #10 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title11.mkv' (title #12)
AV sync issue in stream 4,5 at 0:00:00.019 with duration of 64ms : 2 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.019 with duration of 224ms : 7 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.019 with duration of 256ms : 8 early frame(s) dropped at start
20 titles saved, 1 failed
raever
Post by raever » Sat Sep 20, 2014 12:58 am
Anyone ever get Aladdin to get past 51 minutes, tried makemkv, vidcoder, handbrake .... This is with the above reorder file in the mkv data directory ...
MakeMKV v1.8.13 win(x64-release) started
Opening files on harddrive at C:/Users/sterling/Desktop/DVDs/__/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #11 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
Calculated BUP offset for VTS #15 does not match one in IFO header.
Calculated BUP offset for VTS #16 does not match one in IFO header.
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (33 cell(s), 1:18:32)
Title #22 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #42 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/__/MKV
The source file 'C:/Users/__/VIDEO_TS/VTS_06_2.VOB' is corrupt or invalid at offset 188823552, attempting to work around
Failed to save title 0 to file C:/Users/sterling/Desktop/Transcoded/MKV/title00.mkv
