Rip fails on Aladdin Platinum Edition
When ripping Aladdin Platinum Edition the rip stops/fails at 1691MB using 1.6.16 and 1.7.0 on Linux (LMDE).
The DVD plays fine on XBMC and MythTV, I can also rip the track using DVD::RIP, and can ISO dump the DVD - so suspect that the DVD is fine.
Snippets from the debug log
001003:0020 DEBUG: Code 26 at )%g?@J`{s7?,gR3[Z'X:29398622
RH=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
SP=PMHUAAOkDAAACAAAAAAQAAAAAAAA=
001003:0020 DEBUG: Code 149 at )%g?@J`{s7?,gR3[Z'X:213135067
001003:0020 DEBUG: Code 8 at )%g?@J`{s7?,gR3[Z'X:213135090
FS ID=V_MPEG2 C=162
TI=ZeNpjZICAtVeXMzEQAQ4c2wxWNw2Nz4xDvUPnVDgbpPACkHjAyMAQygyhDUoZGF4yQ+QYWBD6AOlqDR8=
001003:0020 DEBUG: Code 0 at g>"bhI#yq187HE\m>x`|m:213134216
AV sync issues in /home/alan/Videos/Aladdin/title08.mkv
AV sync in 2,3 at 1:02:26.048 (352ms) : audio gap - 11 missing frame(s)
AV sync in 1 at 1:02:25.856 (416ms) : audio gap - 13 missing frame(s)
AV sync in 1 at 1:02:26.304 (32ms) : audio gap - 1 missing frame(s)
005003:0000 Failed to save title 8 to file /home/alan/Videos/Aladdin/title08.mkv
Between the two are long binary strings - last one starts C_00161=. The log is attached as well.
Alan
FS ID=V_MPEG2 C=162
Alan
- MakeMKV_log.txt
- (588.66 KiB) Downloaded 879 times
- Contact:
Re: Rip fails on Aladdin Platinum Edition
A disc mastering error, workaround should be added in the next version.
- Contact:
Please try this workaround - download attached file and place it into "MakeMKV data directory". Please post the result here. This workaround should work with any version after 1.6.16 .
- reord-alladin.txt
- (128 Bytes) Downloaded 947 times
The rip failed with V1.7.1 without the file in my "makemkv data directory". Once that was installed, it worked - thank you. At the same point 1691M it was previously failing, the following were posted to the log
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2277300224, attempting to work around
AV synchronization issues were found in file '/home/alan/Videos/Aladdin/title08.mkv' (title #9)
AV sync issue in stream 1 at 1:02:25.856 with duration of 416ms : audio gap - 13 missing frame(s)
AV sync issue in stream 1 at 1:02:26.304 with duration of 32ms : audio gap - 1 missing frame(s)
I didn't log the debug messages, let me know if you want those.
And thank you again!
cablecoder
I'm running v1.7.4 with the reord-alladin.txt file in the "makemkv data directory" and the rip is still failing for me.
Here is the MakeMKV window output and I'm attaching the debug log file:
MakeMKV v1.7.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Tony/MakeMKV_log.txt
Title #0 has length of 278 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #1 has length of 48 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #2 has length of 84 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #3 has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #4 has length of 124 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #5 has length of 109 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #6 has length of 116 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #7 has length of 33 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #8 has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #9 has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 10-end were skipped due to cell commands (structure protection?)
Title #10 was added (9 cell(s), 0:11:29)
Title #11 has length of 240 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #12 has length of 144 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #13 has length of 236 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #14 has length of 225 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 9-end were skipped due to cell commands (structure protection?)
Title #15 was added (8 cell(s), 0:14:01)
Title #16 has length of 4 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #17 has length of 6 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #18 has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 34-end were skipped due to cell commands (structure protection?)
Title #19 was added (33 cell(s), 1:30:03)
Title #20 was added (5 cell(s), 0:11:31)
Title #21 has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #22 has length of 134 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #23 has length of 147 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #24 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #25 has length of 160 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #27 has length of 19 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #28 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #29 has length of 13 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #30 has length of 3 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #32 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #33 has length of 174 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #34 has length of 347 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #35 has length of 141 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #36 has length of 202 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #37 has length of 228 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #38 has length of 253 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #39 has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #40 has length of 254 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #41 has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/2 has length of 41 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/3 has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/1 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/2 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/3 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/4 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/5 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #45 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #47 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #48 has length of 36 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #49 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #50 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory G:/
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062245888, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062247936, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062249984, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062252032, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062254080, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062256128, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062258176, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062260224, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062262272, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062264320, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062266368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062268416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062270464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062272512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062274560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062276608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062278656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062280704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062282752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062735360, attempting to work around
AV synchronization issues were found in file 'G://title02.mkv' (title #3)
AV sync issue in stream 1 at 0:56:32.704 with duration of 64ms : audio gap - 2 missing frame(s)
AV sync issue in stream 1 at 0:56:32.800 with duration of 32ms : audio gap - 1 missing frame(s)
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276538368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276540416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276542464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276544512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276546560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276548608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276550656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276552704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276554752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276556800, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276558848, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276560896, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276562944, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276564992, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276567040, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276569088, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276571136, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276573184, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276575232, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276577280, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276579328, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276581376, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276583424, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276585472, attempting to work around
DEBUG: Code 27 at |*&l00^yEF{/2wMW.D=:121266856
DEBUG: Code 149 at |*&l00^yEF{/2wMW.D=:29399036
DEBUG: Code 10 at |*&l00^yEF{/2wMW.D=:213135389
DEBUG: Code 0 at SPT>#N;twF^Jnfq+hJ#q2:29397955
AV sync issue in stream 1 at 1:02:25.952 with duration of 192ms : audio gap - 6 missing frame(s)
Failed to save title 2 to file G://title02.mkv
0 titles saved, 1 failed
Any help would be greatly appreciated.
-T
-T
- MakeMKV_log.txt
- (596.28 KiB) Downloaded 736 times
Swap it for a new one.
Aladdin Platinum Edition failed for me at the same place:
So something is obvously wrong here. It is highly unlikely the dwo different disks would fail at the exact same place... The disks looks clean anyway... [and I have make mkv having no problem with reading/copying very dirty/scratched disks]...
I hope somebody could look into it, please.
- Contact:
Please post the full log from the latest version.
the_limper
I am seeing the same issue.
Pertinent info:
MakeMKV v1.8.9 [win(x64-release)]
I have included the full log from an attempt - I left all titles checked even though the main feature is title 8 - this is the title that is failing. (I would attach it but the board gave me a attachment quota error)
Please note that the DVD plays fine in VLC.
Pertinent info:
Title #1 was added (8 cell(s), 0:04:32)
Title #2 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #5 was added (1 cell(s), 0:02:03)
Title #6 has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #12 was added (2 cell(s), 0:03:59)
Title #13 was added (2 cell(s), 0:02:23)
Title #14 was added (2 cell(s), 0:03:55)
Title #15 was added (2 cell(s), 0:03:44)
Title #16 was added (8 cell(s), 0:14:01)
Title #17 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (33 cell(s), 1:30:03)
Title #22 has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 was added (1 cell(s), 0:02:14)
Title #24 was added (1 cell(s), 0:02:27)
Title #25 was added (1 cell(s), 0:02:52)
Title #26 was added (1 cell(s), 0:02:39)
Title #28 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 was added (2 cell(s), 0:02:52)
Title #34 was added (2 cell(s), 0:02:53)
Cells 5-end were skipped due to cell commands (structure protection?)
Title #35 was added (4 cell(s), 0:05:45)
Title #36 was added (1 cell(s), 0:02:20)
Title #37 was added (1 cell(s), 0:03:22)
Title #38 was added (1 cell(s), 0:03:48)
Title #39 was added (1 cell(s), 0:04:10)
Title #40 was added (1 cell(s), 0:02:22)
Title #41 was added (1 cell(s), 0:04:14)
Title #42 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45/5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 21 titles into directory M:/Media/video/ripped_dvd/Video
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062721024, attempting to work around
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title07.mkv' (title #8)
AV sync issue in stream 4,5 at 0:56:32.800 with duration of 160ms : audio gap - 5 missing frame(s)
AV sync issue in stream 2,3 at 0:56:32.704 with duration of 96ms : audio gap - 3 missing frame(s)
Failed to save title 7 to file M:/Media/video/ripped_dvd/Video/title07.mkv
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title08.mkv' (title #9)
AV sync issue in stream 4,5 at 0:00:00.005 with duration of 128ms : 4 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.005 with duration of 256ms : 8 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.005 with duration of 224ms : 7 early frame(s) dropped at start
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title09.mkv' (title #10)
AV sync issue in stream 4,5 at 0:00:00.011 with duration of 128ms : 4 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.011 with duration of 256ms : 8 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.011 with duration of 224ms : 7 early frame(s) dropped at start
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title10.mkv' (title #11)
AV sync issue in stream 4,5 at 0:00:00.014 with duration of 160ms : 5 early frame(s) dropped at start
AV sync issue in stream 1,2,3 at 0:00:00.014 with duration of 256ms : 8 early frame(s) dropped at start
Track #9 turned out to be empty and was removed from output file
Track #10 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'M:/Media/video/ripped_dvd/Video/title11.mkv' (title #12)
AV sync issue in stream 4,5 at 0:00:00.019 with duration of 64ms : 2 early frame(s) dropped at start
AV sync issue in stream 1 at 0:00:00.019 with duration of 224ms : 7 early frame(s) dropped at start
AV sync issue in stream 2,3 at 0:00:00.019 with duration of 256ms : 8 early frame(s) dropped at start
20 titles saved, 1 failed
Anyone ever get Aladdin to get past 51 minutes, tried makemkv, vidcoder, handbrake .... This is with the above reorder file in the mkv data directory ...
MakeMKV v1.8.13 win(x64-release) started
Opening files on harddrive at C:/Users/sterling/Desktop/DVDs/__/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #11 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
Calculated BUP offset for VTS #15 does not match one in IFO header.
Calculated BUP offset for VTS #16 does not match one in IFO header.
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (33 cell(s), 1:18:32)
Title #22 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #42 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/__/MKV
The source file 'C:/Users/__/VIDEO_TS/VTS_06_2.VOB' is corrupt or invalid at offset 188823552, attempting to work around
Failed to save title 0 to file C:/Users/sterling/Desktop/Transcoded/MKV/title00.mkv
