Pioneer bdr 209 and Pioneer bdr 209m
lalalaurel
Re: Pioneer bdr 209 and Pioneer bdr 209m
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Firmware date: 2018-01-15
Highest AACS version: 78
Drive platform: RS8600
Firmware version: E102/ID76
Any help would be appreciated on this drive if possible. I have done this to one of my LGs years ago but I can't find the files for this one...
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
sure just email me that info see email belowlalalaurel wrote: Sat Aug 30, 2025 8:22 pm Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
lalalaurel
Is there another way besides the $25 auto flash kit to accomplish this?
The pioneer flasher is not public yet and I'm once of the authorized testers for itlalalaurel wrote: Sun Aug 31, 2025 3:49 pm Is there another way besides the $25 auto flash kit to accomplish this?
No.lalalaurel wrote: Sun Aug 31, 2025 3:49 pm Is there another way besides the $25 auto flash kit to accomplish this?
Thank you for what you sent! I'm too new to PM you back, but is there a reason why the flasher isn't recognizing my drive? I'm using a Unitek SATA to USB adapter which works well for ripping, and the SDFtool flasher recognizes the drive, if that means anything.Coopervid wrote: Sat Aug 30, 2025 9:36 amPM sent.usmma2014 wrote: Fri Aug 29, 2025 9:00 pm@Coopervid are you able to tell me if I can get this 209M working for UHD? Thanks for your time!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.30
Serial number:
Firmware date: 2014-12-05
Firmware version: 1.30
These flashers work very differently. Either connect it directly to SATA with a computer from a friend or get this USB->SATA adapter which was tested to work.usmma2014 wrote: Tue Sep 02, 2025 1:42 amThank you for what you sent! I'm too new to PM you back, but is there a reason why the flasher isn't recognizing my drive? I'm using a Unitek SATA to USB adapter which works well for ripping, and the SDFtool flasher recognizes the drive, if that means anything.Coopervid wrote: Sat Aug 30, 2025 9:36 amPM sent.usmma2014 wrote: Fri Aug 29, 2025 9:00 pm
OS device name: E:
Revision: 1.30
Serial number:
https://www.amazon.com/BENFEI-Drive-Ada ... r=8-3&th=1
Im sure,
ive seen this many times, but no solution howto crossflash this drive for UHD use. Can you give me a hint where to find the firmware files and how to crossflash it for UHD-usability? I want to burn in linux, if possible. Thats much more convenient on command line
My drive is:
Laufwerksinformation
OS-Gerätename: /dev/sr0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.34
Serienummer: (..)
Firmware-Datum: 2016-04-25
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 75
Firmware version: 1.34/ID61
Tfh!
Oliver
P.S.: Im not able to send a private message here at the moment, but sure I can get some
My drive is:
Produzent: PIONEER
Revision: 1.34
Serienummer: (..)
Tfh!
Oliver
PM sent. Windows only or in a good VM like VMWare.spooch wrote: Wed Sep 03, 2025 2:12 pm Im sure,
ive seen this many times, but no solution howto crossflash this drive for UHD use. Can you give me a hint where to find the firmware files and how to crossflash it for UHD-usability? I want to burn in linux, if possible. Thats much more convenient on command line.
My drive is:
Produzent: PIONEER
Revision: 1.34
Serienummer: (..)
Tfh!
Oliver
P.S.: Im not able to send a private message here at the moment, but sure I can get some![]()
I just got that SATA adapter today to try (thanks for the link!), but unfortunately it still isn't working with BDRFlash. It's the only desktop I have, and it's an HP mini so it has a small ribbon cable SATA connector inside with my OS drive connected to it. I'm not certain that the ribbon cable is supposed to support the current of a 5.25" optical drive, so I may still need auxiliary power in addition to an extended SATA cable for the data. That's after I move my OS to an M.2 NVME drive. I was really hoping I could make use of one of the many USB ports on this thing.Coopervid wrote: Tue Sep 02, 2025 8:50 amThese flashers work very differently. Either connect it directly to SATA with a computer from a friend or get this USB->SATA adapter which was tested to work.usmma2014 wrote: Tue Sep 02, 2025 1:42 amThank you for what you sent! I'm too new to PM you back, but is there a reason why the flasher isn't recognizing my drive? I'm using a Unitek SATA to USB adapter which works well for ripping, and the SDFtool flasher recognizes the drive, if that means anything.
Is there any reason--based on the generated MakeMKV info--a direct SATA connection still might not work with this drive and flasher? Just before I go through all of that.
You should have ordered the adapter with the power supply just like in the link. If you have an external WD hard drive you can use its power supply.
@Coopervid I did order the exact adapter you linked, which has a 12V power supply. It's just like the Unitek. Both work for ripping, but BDRFlash specifically won't recognize the drive.
These power supplies have proven to be plenty for an optical, so I'm thinking it's the communication with the program itself.
Never had any problem like that unless there was a disc in the drive or the tray was not closed. Are you using Windows or an OS with a VM? Not all VMs work. If so, use VMWare.usmma2014 wrote: Mon Sep 08, 2025 9:14 pm @Coopervid I did order the exact adapter you linked, which has a 12V power supply. It's just like the Unitek. Both work for ripping, but BDRFlash specifically won't recognize the drive.
@Coopervid could you send me the files please my data below
OS device name: M:
Revision: 1.54
Serial number: NHDL022831WL
Firmware date: 2020-07-21
Bus encryption flags: 13
Firmware version: 1.54/ID60
OS device name: M:
Revision: 1.54
PM sent.Skull66 wrote: Thu Sep 11, 2025 10:55 am @Coopervid could you send me the files please my data below
OS device name: M:
Revision: 1.54
