Pioneer BDR-UD03 UHD possibility
ud03-swag-gaming
Re: Pioneer BDR-UD03 UHD possibility
#781 Post by ud03-swag-gaming » Thu Aug 28, 2025 10:49 pm
Coopervid wrote: Thu Aug 28, 2025 8:38 am
ud03-swag-gaming wrote: Thu Aug 28, 2025 2:35 am .
PM sent.
I've gotten it flashed and done my first 4K rips! Thanks Coopervid, you're the best!!
Cpt-Sinon
#782 Post by Cpt-Sinon » Sat Aug 30, 2025 6:49 pm
I am in the same boat as everyone else. I've got the Verbatim 43889 which contains the following Pioneer Drive:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 78
Drive platform: RS8511
Firmware version: 1.14
#783 Post by Billycar11 » Sat Aug 30, 2025 7:19 pm
Cpt-Sinon wrote: Sat Aug 30, 2025 6:49 pm I am in the same boat as everyone else. I've got the Verbatim 43889 which contains the following Pioneer Drive:
Revision: 1.14
Serial number: ...
Sure just email me the drive info section see below
Marcel_
#784 Post by Marcel_ » Sun Aug 31, 2025 7:52 am
I have the same issue. It would be great if you also could help me
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ------------
Firmware-Datum: 2020-06-15
_Maki
#785 Post by _Maki » Fri Sep 05, 2025 11:40 am
Would you mind sending me the instructions as well? :)
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Highest AACS version: 71
#786 Post by Billycar11 » Fri Sep 05, 2025 7:09 pm
_Maki wrote: Fri Sep 05, 2025 11:40 am Would you mind sending me the instructions as well? :)
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Yeah just email me that drive info see below for my email
Magicpeople
#787 Post by Magicpeople » Thu Sep 11, 2025 11:09 pm
Hi, I just bought a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Here is the drive info from MakeMKV:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
#788 Post by Coopervid » Mon Sep 15, 2025 9:51 am
Magicpeople wrote: Thu Sep 11, 2025 11:09 pm Hi, I just bought a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Revision: 1.03
Serial number:
PM sent.
Magicpeople
#789 Post by Magicpeople » Thu Sep 18, 2025 10:14 pm
Coopervid wrote: Mon Sep 15, 2025 9:51 am
Revision: 1.03
Serial number:
PM sent.
Thank you, legend!
rixodream
#790 Post by rixodream » Sat Sep 20, 2025 10:44 pm
Wondering if it is possible to flash this? Any assistance would be greatly appreciated. I bought it with the idea it would be plug and play but it was advertised as USB-C and showed up as USB 3.0 flat? Hoping I don't need to make a return.
Revision: 1.14
Serial number:
Highest AACS version: 82
#791 Post by Billycar11 » Sun Sep 21, 2025 6:57 am
rixodream wrote: Sat Sep 20, 2025 10:44 pm Wondering if it is possible to flash this? Any assistance would be greatly appreciated. I bought it with the idea it would be plug and play but it was advertised as USB-C and showed up as USB 3.0 flat? Hoping I don't need to make a return.
Revision: 1.14
Serial number:
sure email me see email below
ChaosEnergy
#792 Post by ChaosEnergy » Mon Sep 22, 2025 10:52 am
Hey
I just noticed my old Laptop has a Pioneer drive
But I cant read UHD
The Laptop is from 2013 or 14
And the drive is named BD-RW BDR-UD03D
So the D might make a difference
But maybe I found the honeypot and can make it read UHD
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03D
Revision: 1.00
Serienummer: NFDL004629WL
Firmware-Datum: 2014-05-14
Highest AACS version: 64
Firmware version: 1.00/ID84
#793 Post by Coopervid » Mon Sep 22, 2025 11:24 am
ChaosEnergy wrote: Mon Sep 22, 2025 10:52 am Hey
But I cant read UHD
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.00
PM sent. You will be good to read UHDs.
Ortho
#794 Post by Ortho » Fri Sep 26, 2025 9:26 pm
Hi, I just picked this drive up! Need assistance on getting it flashed
Revision: 1.14
Serial number:
#795 Post by Billycar11 » Fri Sep 26, 2025 10:56 pm
Ortho wrote: Fri Sep 26, 2025 9:26 pm Hi, I just picked this drive up! Need assistance on getting it flashed
Revision: 1.14
Serial number:
Sure just email me that I do see email below
