Do I need to flash my BDR-XD05
g4x86matrix
Re: Do I need to flash my BDR-XD05
It works greatly and thank you!\ very much!
yes just email me the drive info section see email belowvidster wrote: Sat Aug 30, 2025 9:16 pm I have this drive and it has served me well for years with blu ray rips. Am I reading the posts correctly in that it is possible to to handle UHD?
Here is my drive info:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 68
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Hi there, will my drive also work with UHD?
Many thanks!
Here are the details:
OS device name: /dev/rdisk7
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 66
Drive platform: RS8232
Firmware version: 3.10/ID34
Many thanks!
Revision: 3.10
Serial number:
Yes email me for the flasher just send that info to the email belowcryze wrote: Tue Sep 16, 2025 1:54 pm Hi there, will my drive also work with UHD?
Many thanks!
Revision: 3.10
Serial number:
Redeemed116
OS device name: F:
Revision: 1.21
Serial number:
Firmware date: 2014-04-02
Firmware version: 1.21
Good morning all, I was wondering if my old Pioneer BDR-XD05 is capable of decrypting UHD discs? I am unable to send PM's for whatever reason, probably because my account was just created. Please let me know if this can be done. Thank you!
OS device name: F:
Revision: 1.21
Serial number:
PM sent.Redeemed116 wrote: Sun Oct 12, 2025 3:52 pm Drive Information
OS device name: F:
Revision: 1.21
Serial number:
Redeemed116
When I tried to flash it, I receive an error stating "Drive and firmware hardware don't match." The sticker on the bottom of the drive lists it as BDR-XD05W however, MakeMKV recognizes it as a BDR-XD05.
OS device name: F:
Revision: 1.21
Serial number: NCDL013399UC
OS device name: F:
Revision: 1.21
I had sent the wrong package. Please check your new PM.Redeemed116 wrote: Tue Oct 14, 2025 4:37 am When I tried to flash it, I receive an error stating "Drive and firmware hardware don't match." The sticker on the bottom of the drive lists it as BDR-XD05W however, MakeMKV recognizes it as a BDR-XD05.
OS device name: F:
Revision: 1.21
Redeemed116
I am unable to sign up for Paypal. I also am unable to message you in private. Are you able to send an invoice to the email address that I originally sent you an email from?
TrashPanda
Since it seems like this is the path to getting one of these flashed for ripping uhds, here is my drive info (based on what others have posted in this thread, I'm fairly certain mine will work).
OS device name: G:
Revision: 1.21
Serial number: PGDL900075WL
I would really appreciate your help getting this flashed. Thanks.
OS device name: G:
Revision: 1.21
Just send that info over to my email see belowTrashPanda wrote: Fri Oct 17, 2025 9:31 pm Since it seems like this is the path to getting one of these flashed for ripping uhds, here is my drive info (based on what others have posted in this thread, I'm fairly certain mine will work).
OS device name: G:
Revision: 1.21
standforme
Finally got some UHD discs, so looking to see if I can get a flash for old faithful.
OS device name: /dev/sr1 (I can use Windows, too)
Revision: 3.01
Serial number:
Highest AACS version: 81
Unrestricted read speed: YesRe: Do I need to flash my BDR-XD05
PM sent.standforme wrote: Mon Nov 03, 2025 1:45 am Finally got some UHD discs, so looking to see if I can get a flash for old faithful.Code: Select all
Drive Information OS device name: /dev/sr1 (I can use Windows, too) Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
I'm also looking for help with this drive. Thanks to Coopervid or others who can help!
Revision: 1.20
Serial number: NCDL012674UC
Firmware date: 2013-11-15
Firmware version: 1.20
Revision: 1.20
PM is coming.oranje wrote: Tue Nov 04, 2025 6:16 pm I'm also looking for help with this drive. Thanks to Coopervid or others who can help!
Revision: 1.20
