I've gotten it flashed and done my first 4K rips! Thanks Coopervid, you're the best!!
Pioneer BDR-UD03 UHD possibility
ud03-swag-gaming
Re: Pioneer BDR-UD03 UHD possibility
Cpt-Sinon
I am in the same boat as everyone else. I've got the Verbatim 43889 which contains the following Pioneer Drive:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 78
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Serial number: ...
Sure just email me the drive info section see belowCpt-Sinon wrote: Sat Aug 30, 2025 6:49 pm I am in the same boat as everyone else. I've got the Verbatim 43889 which contains the following Pioneer Drive:
Revision: 1.14
Serial number: ...
Marcel_
I have the same issue. It would be great if you also could help me
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ------------
Firmware-Datum: 2020-06-15
_Maki
Would you mind sending me the instructions as well?
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Highest AACS version: 71
Unrestricted read speed: Yes-
Yeah just email me that drive info see below for my email_Maki wrote: Fri Sep 05, 2025 11:40 am Would you mind sending me the instructions as well?
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.14 Serienummer: Firmware-Datum: 2020-06-15 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 71 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Magicpeople
Hi, I just bought a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Here is the drive info from MakeMKV:
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
Revision: 1.03
Serial number:
PM sent.Magicpeople wrote: Thu Sep 11, 2025 11:09 pm Hi, I just bought a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Revision: 1.03
Serial number:
Magicpeople
Thank you, legend!Coopervid wrote: Mon Sep 15, 2025 9:51 amPM sent.Magicpeople wrote: Thu Sep 11, 2025 11:09 pm Hi, I just bought a BDR-UD03 and would appreciate if I could get the firmware so i can flash it.
Revision: 1.03
Serial number:
rixodream
Wondering if it is possible to flash this? Any assistance would be greatly appreciated. I bought it with the idea it would be plug and play but it was advertised as USB-C and showed up as USB 3.0 flat? Hoping I don't need to make a return.
Revision: 1.14
Serial number:
Highest AACS version: 82
Revision: 1.14
Serial number:
sure email me see email belowrixodream wrote: Sat Sep 20, 2025 10:44 pm Wondering if it is possible to flash this? Any assistance would be greatly appreciated. I bought it with the idea it would be plug and play but it was advertised as USB-C and showed up as USB 3.0 flat? Hoping I don't need to make a return.
Revision: 1.14
Serial number:
ChaosEnergy
Hey
I just noticed my old Laptop has a Pioneer drive
But I cant read UHD
The Laptop is from 2013 or 14
And the drive is named BD-RW BDR-UD03D
So the D might make a difference
But maybe I found the honeypot and can make it read UHD
But I cant read UHD
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03D
Revision: 1.00
Serienummer: NFDL004629WL
Firmware-Datum: 2014-05-14
Highest AACS version: 64
Firmware version: 1.00/ID84
PM sent. You will be good to read UHDs.ChaosEnergy wrote: Mon Sep 22, 2025 10:52 am Hey
But I cant read UHD
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-UD03D Revision: 1.00 Serienummer: NFDL004629WL Firmware-Datum: 2014-05-14 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 64 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.00/ID84 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Ortho
Hi, I just picked this drive up! Need assistance on getting it flashed
Revision: 1.14
Serial number:
Revision: 1.14
Serial number:
Sure just email me that I do see email belowOrtho wrote: Fri Sep 26, 2025 9:26 pm Hi, I just picked this drive up! Need assistance on getting it flashed
Revision: 1.14
Serial number:
