PM sent.meWASHE wrote: Sat Aug 30, 2025 5:50 pm I also have a Pioneer XD07 I'd to use for UHD discs.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8D30
Firmware version: 1.02
BDR-XD07B UHD Flash
Re: BDR-XD07B UHD Flash
Sure just email that info see my email belowmeWASHE wrote: Sat Aug 30, 2025 5:50 pm I also have a Pioneer XD07 I'd to use for UHD discs.
OS device name: F:
Revision: 1.02
Serial number:
maBecker
hey yall i would love if anyone can help me enable UHD on my drive Drive Information
OS device name: /dev/sr0
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Highest AACS version: 76
Firmware version: 1.03
Revision: 1.03
Serial number:
Tommunist
BDR-XD07B UHD Flash
I kindly request help with flashing my HDR-XD07B!
Revision: 1.02
Serial number:
Thank you. All this time, I didn't know I had a drive that could read UHD!
Revision: 1.02
Serial number:
Nova Heart
Finally unpacked all my external media stuf, checking the drive info looks like I'm in luck to flash?
Revision: 1.03
Serial number:
Highest AACS version: 81
PM sent.maBecker wrote: Tue Sep 02, 2025 3:35 am hey yall i would love if anyone can help me enable UHD on my drive Drive Information
Revision: 1.03
Serial number:
PM sent.Tommunist wrote: Sat Sep 13, 2025 2:03 pm Hello,
Revision: 1.02
Serial number:
PM sent.Nova Heart wrote: Sat Sep 13, 2025 10:03 pm Finally unpacked all my external media stuf, checking the drive info looks like I'm in luck to flash?Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.03 Serial number: Firmware date: 2020-08-20 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Spzoid
I'd love to get in on this action! Got a couple of UHD discs I want to rip, and came across this thread. Seems to be exactly what I need. Created an account just now for this, so hoping you can help me out. Thanks!
Revision: 1.03
Serial number: ******
Revision: 1.03
PM sent.Spzoid wrote: Mon Sep 15, 2025 3:10 pm I'd love to get in on this action! Got a couple of UHD discs I want to rip, and came across this thread. Seems to be exactly what I need. Created an account just now for this, so hoping you can help me out. Thanks!
Revision: 1.03
RecentEnthusiast
I would also be interested in a cross-flash.
Revision: 1.02
Serial number: [REDACTED]
PM sent.RecentEnthusiast wrote: Tue Sep 16, 2025 1:17 am I would also be interested in a cross-flash.
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.02 Serial number: [REDACTED] Firmware date: 2019-09-05 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
RecentEnthusiast
Thanks! Will take a look shortly.
zittrig
Question about comparing firmware for this drive:
I've a (silver) BDR-XD07TS flashed to a BDR-XD07U 1.04.
Now, a friend of mine will sell his BDR-XD07TUHD (fine black, it's tasting better for my eyes than my silver one) but it has firmware BDR-XD07U with version 1.03.
Which firmware version is better or are there no differences?
This "U" drive should already be UHD capable. I assume the difference is minor between 1.03 and 1.04. Maybe they added some media codes for burning.zittrig wrote: Thu Sep 18, 2025 4:22 pm Question about comparing firmware for this drive:
Now, a friend of mine will sell his BDR-XD07TUHD (fine black, is tasting better for my eyes than my silver one) but it has firmware BDR-XD07U with version 1.03.
P.S.: You kow the song "Paint it black", don't you? Or put your sunglasses on if it's too shiny.
