Software Key
Software Key
I purchased MakeMKV for my Mac System which I no longer use. I'm now using a Win7 Workstation and would like to know whether I need to purchase a new key?
setarip_old
Re: Software Key
IIRC, you are permitted to use your ONE purchased key on any machine(s) you own - as long as you don't use it on more than one machine at a time...
Re: Software Key
Okay, let me rephrase the question. I'm using the same machine however I previously owned the Mac OSX version of. MakeMKV however since I'm now using Win7 the key no longer work. Do I have to purchase the Win7 version.
Re: Software Key
No.
