LibreDrive for Pioneer drives
Dr.Shaw
#1591 Post by Dr.Shaw » Sat Aug 30, 2025 12:16 pm
I have a drive, Pioneer BDR-X13, bought with the modification to rip UHD already applied because I'm not so technical myself. :oops:
And it was all fine, ripped loads of discs. Now I tried it today and it won't read a 4K disc. First time I've used it for 4K in maybe a year I guess.
I remember the MakeMKV status for the drive used to say "MT1959" and that this was somehow important, but I noticed that is NOT there now.
Could it somehow regain the ability it had? Where's it gone?!? Hoped to get "The Shining" from my disc to drive this afternoon but not looking good now! :lol:
#1592 Post by dcoke22 » Sat Aug 30, 2025 3:22 pm
If your drive really is a Pioneer, it would not have said MT1959. MT1959 would indicate an LG based drive.
In any case, copy & paste the MakeMKV drive info (from the first screen of MakeMKV) into a post on the forum.
Dr.Shaw
#1593 Post by Dr.Shaw » Sat Aug 30, 2025 4:13 pm
Right, the 1959 was what I thought I could remember seeing, perhaps that's just something I remember from message posts around the forums.
It is definitely Pioneer though, the logo is on the drive. This is what MakeMKV says:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.04
Serial number: DDDL000915WL
Firmware date: 2023-08-01
Highest AACS version: 81
Drive platform: Pioneer RS9400
Firmware version: ID56
Like I say, it worked fine last year but today it won't even accept a UHD, so I really don't know what the issue might be.
#1594 Post by dcoke22 » Sat Aug 30, 2025 4:46 pm
Revision: 1.04
If you purchased the drive from a seller on this board and it supported UHD, the firmware date would've been before December 2022. The LibreDrive status would've said 'enabled' and it would've worked with UHDs.
Pioneer released firmware dated December 2022 specifically to disable MakeMKV's support for ripping UHDs with Pioneer drives. All firmware after that date disables MakeMKV's ability to rip UHDs and prevents the firmware from being flashed with an older version of the firmware. Pioneer firmware update February 2023
So, it would appear that a firmware update has been applied to the drive and now it is only useful ripping DVDs and regular blu-rays with MakeMKV.
Mike, MakeMKV's author, has stated that eventually all Pioneer drives regardless of firmware level will be supported, but there's no ETA for when this will be. All Pioneer drives will be LibreDrive supported For this drive to rip UHDs again, that support will have to be released.
Dr.Shaw
#1595 Post by Dr.Shaw » Sat Aug 30, 2025 5:22 pm
Revision: 1.04
Thanks for explaining about that. I had wanted to buy one off this board but there was some reason I couldn't (not shipping to UK maybe?) so it was bought off ebay. It definitely was all working fine last year though so I guess a firmware got installed since, not something I knowingly did. I have used the drive for non-UHD discs some months ago so quite possible I clicked a pop up window without realising what was happening.
Good to hear that it will be supported in future. I've found it to be a really good drive for burning discs so my simplest option now might be to get a new cheap drive for 4K if I really have to rip something. Not an urgent issue, I do have "The Shining" on AppleTV already so I could use that instead of a rip for now.
mordred55
#1596 Post by mordred55 » Sun Aug 31, 2025 5:50 pm
Hello new to the forum and was wondering if anything can be done with the following drive.
OS device name: /dev/sr1
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number:
Firmware date: 2018-04-26
Highest AACS version: 77
Firmware version: ID19
Thanks in advance
#1597 Post by Billycar11 » Sun Aug 31, 2025 11:01 pm
Revision: 1.21
Serial number:
Thanks in advance
Yes but windows only email me that drive info
See below
newsoftheworld
#1598 Post by newsoftheworld » Tue Sep 02, 2025 1:26 pm
Hi All,
Apologies in advance if this has already been answered somewhere. I have a Pioneer BDR-XD07TS (Mfd Dec 2020) which I mainly have used for ripping CD's but also some DVD's and Blu-rays. I had wanted to upgrade it to be able to read UHD discs if possible?
OS device name: /dev/rdisk7
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TLDx
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest
AACS version: 75
Drive platform: Pioneer RS8D30
Firmware version: GENE
On another note although the drive can read blu-rays it seems to have become flakey these days at reading cd's. I have cleaning the lens... it works sometimes but most times behaves flakey so hoped the revised firmware allows it to read cd's again. Although realise it may have come to the end of its life.
I would appreciate any help. Thank you
dlordofdarkness
#1599 Post by dlordofdarkness » Tue Sep 02, 2025 1:26 pm
I found an old Pioneer drive and would like to use it for MakeMKV 4K UHD Ripping of my collection. Will this work?
Information
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number:
Firmware date: 2014-04-02
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21
zhwghl
#1600 Post by zhwghl » Tue Sep 02, 2025 4:01 pm
Can this drive be used?
OS device name: H:
Product: BD-RW BDR-XD06U
Revision: 1.00
Serial number: QDDL000516JP
Firmware date: 2017-02-24
Drive platform: Pioneer RS8B30
Firmware version: ID69
Disc Information
Label: TRANSFORMERS AGE OF EXTINCTION
Timestamp: 2017-09-29 15:17:42
Protection: AACS2.0/C v61
Data capacity: 92.34 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
#1601 Post by Billycar11 » Tue Sep 02, 2025 9:20 pm
Information
Revision: 1.21
Serial number:
Yes email me that drive info see below for email
#1602 Post by Billycar11 » Tue Sep 02, 2025 9:21 pm
OS device name: H:
Revision: 1.00
Disc Information
Number of layers: 3
Yes email me that info for the flash see below for email
#1603 Post by dcoke22 » Wed Sep 03, 2025 3:10 am
Hi All,
Revision: 1.06
Serial number: TLDx
Highest
AACS version: 75
Your firmware is too new. Pioneer released firmware dated December 2022 specifically to disable MakeMKV's support for ripping UHDs with Pioneer drives. All firmware after that date disables MakeMKV's ability to rip UHDs and prevents the firmware from being flashed with an older version or different version of the firmware. Pioneer firmware update February 2023
newsoftheworld
#1604 Post by newsoftheworld » Wed Sep 03, 2025 7:28 am
Hi dcoke22,
Thank you for your reply. I remember flashing it myself thinking I was doing the right thing by keeping up to date with the updates for the drive. I'll be more cautious going forwards.
zhwghl
#1605 Post by zhwghl » Wed Sep 03, 2025 11:27 pm
OS device name: H:
Revision: 1.00
Disc Information
Number of layers: 3
Thank you for your reply. I have sent an email to you.
