Do I need to flash my BDR-XD05
buyitownit
Hi! I'm new to this as I recently decided to cancel crappy Netflix and build a real media collection. I've got around 100 DVD/Blu-ray discs and would like to use MakeMKV to put them on my Plex server.
I've found an old Pioneer BDR-XD05 and am hoping I can use it to rip my collection. Here the stats from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number: ...
Firmware date: 2014-04-02
Highest AACS version: 65
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21
I've read a lot about flashing firmware, do I need to flash this drive? Can someone hold my hand and help?
Revision: 1.21
Serial number: ...
Re: Do I need to flash my BDR-XD05
It will work for DVD and BD anyway. If you intend to rip UHDs just reply to this and we can make it happen.buyitownit wrote: ↑Wed Jun 11, 2025 5:05 pmHi! I'm new to this as I recently decided to cancel crappy Netflix and build a real media collection. I've got around 100 DVD/Blu-ray discs and would like to use MakeMKV to put them on my Plex server.
Revision: 1.21
Serial number: ...
buyitownit
Yes, having UHD capability would be ace!
PM sent.
buyitownit
Amazing! Thank you.
Does this look correct?
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 66
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
Revision: 1.11
Serial number:
Put an UHD in your drive and you will start smiling...buyitownit wrote: ↑Wed Jun 11, 2025 7:54 pmAmazing! Thank you.
Revision: 1.11
Serial number:
buyitownit
Great! I will find a UHD and give it a try!
I was wondering if I could also get some assistance?
OS device name: E:
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 76
Firmware version: 3.01/ID34
OS device name: E:
Revision: 3.01
Serial number:
PM sent.labe225 wrote: ↑Fri Aug 29, 2025 1:01 amI was wondering if I could also get some assistance?
OS device name: E:
Revision: 3.01
Serial number:
Thanks, everything worked flawlessly!Coopervid wrote: ↑Fri Aug 29, 2025 10:35 amPM sent.labe225 wrote: ↑Fri Aug 29, 2025 1:01 amI was wondering if I could also get some assistance?
OS device name: E:
Revision: 3.01
Serial number:
Can firmware be flashed for UHD read?
Revision: 3.10
Serial number:
Drive platform: RS8232
Firmware version: 3.10/ID34
Revision: 3.10
Serial number:
yes email me that drive info section see below for emailMonyx wrote: ↑Sat Aug 30, 2025 1:00 amCan firmware be flashed for UHD read?
Revision: 3.10
Serial number:
g4x86matrix
I bought my Pioneer BD-RW BDR-XD05 six years ago, but after upgrading its official firmware once, its access to UHD was disabled. Can I get some assistance to re-enable its UHD functions?
The drive info is the following:
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 3.10
Serial number:
Thanks a lot for any help!
Revision: 3.10
Serial number:
PM sent.g4x86matrix wrote: ↑Sat Aug 30, 2025 2:14 pmI bought my Pioneer BD-RW BDR-XD05 six years ago, but after upgrading its official firmware once, its access to UHD was disabled. Can I get some assistance to re-enable its UHD functions?
Revision: 3.10
Serial number:
I have this drive and it has served me well for years with blu ray rips. Am I reading the posts correctly in that it is possible to to handle UHD?
Here is my drive info:
OS device name: E:
Revision: 3.01
Serial number:
Highest AACS version: 68
OS device name: E:
Revision: 3.01
Serial number:
