I have a copy of both Superman's digital release with Dolby Vision and an ISO of the movie but somehow without Dolby Vision, just HDR. It's a legit copy otherwise. Is there a way for me to merge the DV stream to the MKV of the disc? I can send both to anyone who can help.
I've seen the tutorial but since the film's yet to be released until next month, I can't verify the plot.
You've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
it should have DV though: https://www.blu-ray.com/movies/Superman ... ay/378494/
It should have DV but here's the MediaInfo:RESET_9999 wrote: ↑Fri Aug 29, 2025 10:57 amYou've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
General
Unique ID : 217260551878948670668575265626170129968 (0xA372DC39FC159BF2603A5873170CFE30)
Complete name : C:\Video\Superman\Superman_t01.mkv
Format : Matroska
Format version : Version 2
File size : 59.6 GiB
Duration : 2 h 9 min
Overall bit rate mode : Variable
Overall bit rate : 65.9 Mb/s
Frame rate : 23.976 FPS
Title : Superman
Encoded date : 2025-08-28 02:31:42 UTC
Writing application : MakeMKV 1.18.1 win(x64-release)
Writing library : libmakemkv 1.18.1 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medi : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 60.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.306
Stream size : 55.0 GiB (92%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primar : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Le : 180 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medi : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 738 kb/s
Maximum bit rate : 5 781 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.38 GiB (6%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 592 MiB (1%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Dialog Normalization : -24 dB
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -24 dB
dialnorm_Minimum : -24 dB
dialnorm_Maximum : -24 dB
Audio #3
ID in the original source medi : 4353 (0x1101)
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Text #1
ID in the original source medi : 4768 (0x12A0)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 8 min
Bit rate : 51.9 kb/s
Frame rate : 0.446 FPS
Count of elements : 3450
Stream size : 47.9 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
ID in the original source medi : 4772 (0x12A4)
Format : PGS
Duration : 59 min 56 s
Bit rate : 635 b/s
Frame rate : 0.007 FPS
Count of elements : 25
Stream size : 279 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:09:17.557 : en:Chapter 02
00:17:50.069 : en:Chapter 03
00:26:45.604 : en:Chapter 04
00:36:45.203 : en:Chapter 05
00:43:40.618 : en:Chapter 06
00:50:22.019 : en:Chapter 07
00:58:31.508 : en:Chapter 08
01:07:28.044 : en:Chapter 09
01:16:36.592 : en:Chapter 10
01:23:50.025 : en:Chapter 11
01:31:11.466 : en:Chapter 12
01:39:03.938 : en:Chapter 13
01:49:01.535 : en:Chapter 14
01:59:00.133 : en:Chapter 15
02:08:21.694 : en:Chapter 16
Hmm, the back of the retail box shows Dolby Vision for sure, so unless it's weird authoring mistake, maybe you should also try and remux from .m2ts using mkvtoolnix or latest DGDemux to confirm?
uhdiznotenough4mee
Are you using some newer MediaInfo version or some old version?FLarnhill wrote: ↑Fri Aug 29, 2025 2:40 pmIt should have DV but here's the MediaInfo:RESET_9999 wrote: ↑Fri Aug 29, 2025 10:57 amYou've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
General
Format : Matroska
Title : Superman
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : No
Forced : No
Audio #1
Codec ID : A_TRUEHD
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Text #1
Format : PGS
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 635 b/s
Language : English
Default : No
Forced : No
Menu
I'm using the MediaInfo provided by my MPC.uhdiznotenough4mee wrote: ↑Fri Aug 29, 2025 7:18 pmAre you using some newer MediaInfo version or some old version?
For people using DGDemux: when you demux a DV disc, do you retain or not retain the EOS/EOB NALUs? 95% of the time I replace with a cm4.0 RPU, but in some cases, I use the retail RPU. Any recommendation around what to do with EOS/EOB NALUs retain option? Thanks!
EDIT: Another question: Does anyone know what MakeMKV or MKVToolnix's behavior is in this regard? Do they retrain the EOS/EOB NALUs or are they removed from the merged streams?
uhdiznotenough4mee
I do not retain them, so I do not use "-keepeos" flag.jayper wrote: ↑Sat Aug 30, 2025 5:40 pmFor people using DGDemux: when you demux a DV disc, do you retain or not retain the EOS/EOB NALUs? 95% of the time I replace with a cm4.0 RPU, but in some cases, I use the retail RPU. Any recommendation around what to do with EOS/EOB NALUs retain option? Thanks!
Do we know what is most recommended for ugoos playback?
So, I've done all of this and the same outcome: no DV. Given the fact this movie has a Dolby grade for disc, should it be easier to make a hybrid? Or should I still check the brightness and frame delays?skull88 wrote: ↑Fri Aug 29, 2025 2:52 pmHmm, the back of the retail box shows Dolby Vision for sure, so unless it's weird authoring mistake, maybe you should also try and remux from .m2ts using mkvtoolnix or latest DGDemux to confirm?
Rororororo
Could you check the .m2ts file with BDInfo?
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
Dolby Vision 2
https://www.techpowerup.com/340580/dolb ... y-vision-2
After reading the entire article, sounds like (from what I can discern so far) more of a beefed up DV IQ - two way tone mapping is (assumingly) talking about matching content to the screen traditionally, and then matching the screen to the environment via camera/light inputs etc. Besides the new things they talk about like auto black/white matching? and motion control!Dolby Laboratories, Inc., a leader in immersive entertainment experiences, today announced Dolby Vision 2, a groundbreaking evolution of its industry-leading picture quality innovation. Hisense is the first TV brand to announce it will bring Dolby Vision 2 to its lineup of premium televisions, such as RGB-MiniLED TVs. This is complemented by the leading French media and entertainment company CANAL+, which has also announced its commitment to support Dolby Vision 2.
For over a decade, Dolby Vision has pushed picture quality forward as the gold standard for premium HDR. Dolby Vision 2 builds on this success and is designed specifically to meet the evolving opportunities of television experiences today, serving as one piece of Dolby's broader mission to advance picture quality across all entertainment and devices, from the biggest to smallest screens.
@RESET_9999
how long does is take to make a RPU for a movie?
With my pc i9 13900ks + RTX 3070 + pci-e gen4 7gbps drives for a 1h30 movie:
prores encoding: 20-25min
scene cut detection: 10min
DV analysis: 10min
injecting remuxing: 6-8min
If I decide to do trim pass(es), then it can take me hours to monitor each shot one by one and make target adjustments
DV analysis: 10min
wow, i didn't know it was time-consuming like this with your high-end pc.RESET_9999 wrote: ↑Thu Sep 04, 2025 8:02 pmWith my pc i9 13900ks + RTX 3070 + pci-e gen4 7gbps drives for a 1h30 movie:
DV analysis: 10min
