#961 Post by MartyMcNuts » Fri Aug 29, 2025 12:03 am
tbrady3742@aol.com wrote: Thu Aug 28, 2025 11:59 pm
MartyMcNuts wrote: Sun Feb 17, 2019 3:30 am ****** UPDATE: Please use the more recent SDFtool Flasher, available in thread viewtopic.php?f=16&t=22896. No need for the hybrid firmware anymore either. Cheers! ******
Tried running but got message "UPDATE FAILED #5"
Hi everyone,
Just to give you all another option, I have modified the official ASUS ODD FW Flasher tool to allow the user to flash or cross-flash their drive to a "UHD Friendly" firmware.
Included with the ASUS Flasher, is the 'DE' UHD friendly firmwares we are currently using with the LG Flasher tool.
Also, if you happen to use your own clean firmware file that hasn't been 'DE' enabled, this app will automatically make the file 'DE' enabled and save it.
It is very easy to use:
1. Run ASUS_ODD_FW_Changer_(Modified).exe.
2. In popup window, select a firmware file to flash. (If you click CANCEL, the auto default firmware is ASUS BW-16D1HT 3.02)
3. When the main interface opens, select your drive (if not already selected)
4. Hit "START" button. The drive tray will open. Once firmware flash is completed, drive tray will close again.
5. Done.
EDIT (24.08.2019): I have updated the Modified ASUS Flasher which will now allow:
  • The LG BP60NB10 external UHD drive to be flashed with firmware LG_BP60NB10_1.00_MK only.
  • The LG BP50NB40 external Blu-Ray drive to be flashed with firmware LG_BP50NB40-NB50_1.01_MK only. (Not UHD friendly but enables libredrive.)
EDIT (03.09.2019):
I have created 2 modified (hybrid = HBD) firmwares solely for the BP50NB40. Firmware BP60NB10_1.00_MK_HBD will allow you to flash your BP50NB40 to BP60NB10. Firmware BP50NB40-NB50_1.01_MK_HBD will allow you to go back to BP50NB40_1.01_MK if you ever require it. The firmware zip is below.
EDIT (01.01.2020):
Depending on what firmware your BP50NB40 comes with (1.01, 1.02 or 1.03), please flash the corresponding firmware BP50NB40 NB50 1.xx_MK from the MK pack first, then you can cross-flash using the hybrid BP60NB10 1.00 firmware.
Hybrid_Firmware_for_BP50NB40_to_BP60NB10.zip
EDIT (22.05.2020):
Below is the link to the modified ASUS FW Flasher + Downgrade Enabled Firmware + the latest MK firmware pack (20/07/2020):
https://www.mediafire.com/file/mezq26ac ... 9.zip/file
Here is just the modified ASUS Flasher if you don't need the firmwares. Just put it in the folder with the firmwares.
ASUS_ODD_FW_Changer_(Modified) (24.08.2019).zip
Have fun guys!!
As per the first line:
This old flashing tool should no longer be used. SDFtool Flasher is the newer and safer flashing tool.
tbrady3742@aol.com
#962 Post by tbrady3742@aol.com » Fri Aug 29, 2025 12:22 am
MartyMcNuts wrote: Fri Aug 29, 2025 12:03 am
Sorry to bug you but not very good with this mess. I have the ASUS BW-16D1HT. Where do I go to get the firmware update so it will be able to rip 4Ks? Other one messed up after I updated makeMKV. Sorry to be a pest.
Hi everyone,
5. Done.
EDIT (03.09.2019):
EDIT (01.01.2020):
EDIT (22.05.2020):
Have fun guys!!
#963 Post by MartyMcNuts » Fri Aug 29, 2025 1:46 am
tbrady3742@aol.com wrote: Fri Aug 29, 2025 12:22 am
I already told you! Go to the SDFTool Flasher thread (link above), download the latest SDFtool Flasher and the firmware pack in the first post.
tbrady3742@aol.com
#964 Post by tbrady3742@aol.com » Fri Aug 29, 2025 3:09 am
MartyMcNuts wrote: Fri Aug 29, 2025 1:46 am
got error message "Command produced error code 0x8205603"
#965 Post by MartyMcNuts » Fri Aug 29, 2025 4:38 am
tbrady3742@aol.com wrote: Fri Aug 29, 2025 3:09 am
Take the disc out of the drive. It must be empty when flashing!
tbrady3742@aol.com
#966 Post by tbrady3742@aol.com » Fri Aug 29, 2025 7:08 pm
MartyMcNuts wrote: Fri Aug 29, 2025 4:38 am
There wasn't a disc in the drive. It was the wrong patch but found right one. After I write it, do I do the recovery?? Saw then doing it in example of was it there just as example of recovery?
tbrady3742@aol.com
#967 Post by tbrady3742@aol.com » Fri Aug 29, 2025 7:57 pm
Disc wasn't in the there. Was using the wrong firmware but found the right one. Thanks for helping with this. I know it had to be a little aggravating but thanks. Now I can finally rip the 22 4Ks I got.
#968 Post by Coopervid » Fri Aug 29, 2025 8:08 pm
tbrady3742@aol.com wrote: Fri Aug 29, 2025 7:57 pm
Your posts just quoting old posts were quite annoying and not helpful to help you. Just some feedback.
player1
#969 Post by player1 » Sun Nov 23, 2025 7:40 pm
MartyMcNuts wrote: Sat Sep 26, 2020 11:17 pm
njweb wrote: Sat Sep 26, 2020 4:36 am
MartyMcNuts wrote: Sat Sep 26, 2020 1:42 am The Archgon (BU40N) is an excellent drive. I have one myself!
It will most likely be delivered to you with firmware 1.01. Regardless, the best firmware for this drive is DE_LG_BU40N_1.00. It fully enables UHD ripping and is compatible with more (other) software.
Thanks for the help Marty!
Glad I picked it then :)!. I had done some research and I felt it was a great deal for a rebadged (LG BU40N) UHD-capable slim external burner.
I will use the flasher I linked to in my post then and select the DE_LG_BU40N_1.00 then.
I assume that the Asus ODD FW Changer flasher will allow me to downgrade to the above firmware, regardless of which OEM version it ends up shipping with?
(My drive arrives tomorrow).
Looking forward to getting it!
You can use the ASUS flasher or the newer SDFtool Flasher (just unzip it to the same folder as the ASUS flasher/firmware). Either will do the trick!
If the drive arrives with 1.01 on it, you can flash directly to DE_LG_BU40N_1.00.
If it comes with 1.02 or 1.03, it becomes a 2 step process:
1. Flash the matching MK firmware from the "old" folder in the MK pack first, ie: 1.02 --> HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218
2. Then you can flash DE_LG_BU40N_1.00.
Tried this with both the asus and the sdftool flasher 1.36. The asus one keeps saying updating failure #1. The sdftool just does nothing.
Same drive obviously and firmare 1.02. So now I don't know what to do anymore.
#970 Post by dcoke22 » Sun Nov 23, 2025 10:41 pm
player1 wrote: Sun Nov 23, 2025 7:40 pm
You're probably hitting this: PSA: New Archgon UHD drives do not allow flashing
player1
#971 Post by player1 » Mon Nov 24, 2025 1:38 pm
dcoke22 wrote: Sun Nov 23, 2025 10:41 pm You're probably hitting this: PSA: New Archgon UHD drives do not allow flashing
So I'm sol then huh? Can someone recommend a similar drive for a similar price ($140) in the us?
#972 Post by MartyMcNuts » Mon Nov 24, 2025 11:35 pm
player1 wrote: Mon Nov 24, 2025 1:38 pm
Return the Archgon. The Verbatim 43888 has the same BU40N drive inside and is easy to flash.
Krondorf
#973 Post by Krondorf » Sun Dec 14, 2025 8:42 am
Hi guys,
I've got a Buffalo BRXL-PC6U2B-AP that i cannot get to work on my newest PC.
I don't know if it's a windows 11 thing or new hardware thing, but the drive works perfectly on an older PC running windows 10.
I FEEL like it's some sort of artificial limitation being imposed for some reason...
Do you guys know if there's some way to flash it to a version of FW that will allow it to work on my new PC? Or do i have to buy a new BD drive?
TIA
#974 Post by Billycar11 » Sun Dec 14, 2025 3:39 pm
Krondorf wrote: Sun Dec 14, 2025 8:42 am Hi guys,
TIA
Post your makemkv drive info section
Krondorf
#975 Post by Krondorf » Mon Dec 15, 2025 7:55 am
Billycar11 wrote: Sun Dec 14, 2025 3:39 pm
TIA
Actually, don't worry :) I just worked out that the drive has a double ended usb cable that the newer PC needs both..
BUT having said that.. is there anything i can do with this one to enable UHD?
OS device name: E:
Current profile: CD-RW
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 2.00
Serial number: WP44 145787
