This worked like a charm. thank you so much!Coopervid wrote: Sun Aug 24, 2025 8:35 pmPM sent.willkg118 wrote: Sun Aug 24, 2025 7:30 pm Greetings @Coopervid
I saw this thread. I hope you're reading it. I just bought a Pioneer BDR-212V. I'm hoping these specs show that I'm able to flash its firmware
I hope this version is good. thank you in advance!Code: Select all
Drive Information OS device name: \Device\CdRom0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: REMOVED Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
- Will
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Sure email me that drive info see belowRobertTX wrote: Sun Aug 24, 2025 9:21 pm Just joined the group and hope you can help me flash my drive.
Info follows:
OS device name: G:
Revision: 1.02
Serial number:
Thank you in advance
Appreciate your help getting this drive working
OS device name: E:
Revision: 1.02
Serial number: XXXXX
OS device name: E:
Revision: 1.02
sure just email me that drive info see belowdavahad wrote: Mon Aug 25, 2025 10:25 pm Appreciate your help getting this drive working
OS device name: E:
Revision: 1.02
Another one
OS device name: F:
Revision: 1.00
Serial number: AEDL012664WL
Firmware date: 2020-08-07
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.00/ID06
OS device name: F:
Revision: 1.00
PM sent.another30 wrote: Thu Aug 28, 2025 7:12 am Another one
OS device name: F:
Revision: 1.00
Hello
Just got the Pioneer BD-RW BDR-212V, any help in flashing it to work with UHD discs would be appreciated. Thanks
Revision: 1.02
Serial number: XXXXXXXXX
Highest AACS version: 82
Revision: 1.02
PM is coming.mrmaxie wrote: Fri Aug 29, 2025 6:10 pm Hello
Revision: 1.02
Next on the list, help appreciated.
Product: BD-RW BDR-212D
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Highest AACS version: 68
Firmware version: 1.00/ID61
Revision: 1.00
Serial number:
sure email that drive info see belowbrazil wrote: Fri Aug 29, 2025 11:36 pm Next on the list, help appreciated.
Revision: 1.00
Serial number:
Managed to nab one the linked 212V drives before they went out of stock. I don't think I fully understand what the flashing does/unlocks (can it be made to read/rip UHD?), but here is the info for my drive:
Revision: 1.02
Serial number: DGDL--------
Thanks to all of you guys for this resource
Revision: 1.02
PM sent.helipad wrote: Thu Sep 04, 2025 2:07 am Managed to nab one the linked 212V drives before they went out of stock. I don't think I fully understand what the flashing does/unlocks (can it be made to read/rip UHD?), but here is the info for my drive:
Revision: 1.02
@Coopervid
New to forum so can't PM you directly. Looking to flash the following below for 4K. It's a 212M but think that this should fall under the same heading.
OS device name: E:
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: [REDACTED]
Firmware date: 2020-07-21
Highest AACS version: 76
Firmware version: 1.01/ID56
Look forward to hearing from you.
OS device name: E:
Revision: 1.01
PM sent.nbmake wrote: Thu Sep 04, 2025 9:49 pm @Coopervid
OS device name: E:
Revision: 1.01
Appreciate the quick reply. Worked perfectly. Thanks again!
