Correct playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
Can anyone help in regards to the correct playlist for both the theatrical and extended version of the movie?
thank you
Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
Re: Robin Hood: Prince Of Thieves 1991-Arrow remastered blu-ray
I Got the same issue. i even Got Libra Drive. can someone help?
DVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
@dcoke22 - yes there are two cuts of the movie. problem is that there is a lot of playlists for each version when you rip the disc - even with libredrive and java installed.
Did you ever find out?duranduran wrote: ↑Sun Nov 26, 2023 9:36 amCorrect playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
thank you
@dcoke22 - yes there are two cuts of the movie. problem is that there is a lot of playlists for each version when you rip the disc - even with libredrive and java installed.dcoke22 wrote: ↑Fri Aug 22, 2025 11:22 pmDVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
did you find the right one? thanksJacobHeldt wrote: ↑Sat Aug 23, 2025 1:30 pmDid you ever find out?duranduran wrote: ↑Sun Nov 26, 2023 9:36 amCorrect playlist for Robin Hood: Prince Of Thieves 1991 - Arrow remastered blu-ray
thank you
as i wrote its a playlist issue - cause the disc has a large amount of playlist for each version - i have libredrive and Java installed - would you have any idea what to do?dcoke22 wrote: ↑Fri Aug 22, 2025 11:22 pmDVDCompare.net (https://www.dvdcompare.net/comparisons/film.php?fid=62987) suggests the theatrical version is 143:12 and the extended version 155:02.
thansk J
I don't have that disc, so I don't know what the proper playlists are. This thread has various methodologies you can try. A Better Way To Find The Correct Playlist/Segment Map
thanks a lot.dcoke22 wrote: ↑Fri Aug 29, 2025 2:27 pmI don't have that disc, so I don't know what the proper playlists are. This thread has various methodologies you can try. A Better Way To Find The Correct Playlist/Segment Map
