Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
GDNCHN!
Post by GDNCHN! »
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E116/ID71
The biggest difference between my drive and the common ones is that its firmware is "E116", compared to the often-seen ones with "E114" or "E115" firmware. But since the LibreDrive is enabled, I put an UHD disc inside. Surprisingly, after a while of reading, MakeMKV just simply told me that there is "No Disc" inside. That's awful. What should I do, or which firmware should I patch since its chip is not MT1959?
ILikeCupcake
Re: Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
Post by ILikeCupcake »
Hey, I have the same issue.
Did you find a way to enable UHD ?
Have a nice day !
GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
ILikeCupcake wrote: Thu Aug 28, 2025 4:41 pm Hey, I have the same issue.
Have a nice day !
Post yor Makemkv info.
ILikeCupcake
Coopervid wrote: Thu Aug 28, 2025 8:52 pm
Have a nice day !
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 50
ILikeCupcake wrote: Thu Aug 28, 2025 10:45 pm
Have a nice day !
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
Randow
Post by Randow »
Hello Guys, i have the same Drive and also cant read UHD Blu Rays. Do You Guys found a fix ?
Randow wrote: Sat Aug 30, 2025 3:31 pm Hello Guys, i have the same Drive and also cant read UHD Blu Rays. Do You Guys found a fix ?
Post your Makemkv info.
Randow
Post by Randow »
Hey, this is my MakeMKV Info.
Laufwerksinformation
OS-Gerätename: H:
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer: DEDL115184WL
Firmware-Datum: 2020-07-21
Highest AACS version: 72
Randow wrote: Sat Aug 30, 2025 4:54 pm Hey, this is my MakeMKV Info.
OS-Gerätename: H:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
PM sent.
somebody1121
Post by somebody1121 »
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr0
Fabricante: ASUS
Producto: BW-16D1H-U
Revisión: E116
Número de serie: CEDL092768WL
Fecha del firmware: 2020-07-21
Marcas de cifrado bus: 1B
It's there a way to make this drive read UHD?
somebody1121 wrote: Tue Sep 02, 2025 6:43 pm Información de unidad de disco
Fabricante: ASUS
Revisión: E116
PM sent.
StrahlemannLP
Post by StrahlemannLP »
Hey folks,
have the same issues with a freshly bought drive:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Highest AACS version: 76
Your help is very much appreciated.
sugi1
Post by sugi1 »
I seem to have the same problem. Any help is appreciated.
Drive info:
Loaded SDF.bin version 0x98
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:RS8F00
8015:Firmware name
:PIONEER BDR-212T
8002:Firmware type
8106:Original (unpatched)
8003:Firmware version
:E116/ID71
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:01.0
:D0CE65A7F569
Identification SDF present
8013:Status
8001:Drive platform
:Pioneer RS8F00
:ID71
pioneer:SAT :8F00:ID71:    :ASUS    :BW-16D1H-U      E116: 20/07/21  :-
StrahlemannLP wrote: Sat Sep 13, 2025 2:35 pm Hey folks,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
