Very loww CPU usage when saving title
lomppu
Post by lomppu »
Hello! I've been using MakeMKV for a long time, I love it, and I'm very grateful it exists.
It's been a while since I had a computer with an optical drive, so I can't say for sure if this has always been the case or not, so please excuse me if I'm posting old news here.
Anyway, I fired up a mid 2010 Macbook Pro with a 2,4Ghz Intel Core Duo CPU running Mavericks to backup some DVDs. During the operation "Saving 1 titles into directory ..." the MacOs Activity Monitor reports MakeMKV using around 3% of the available CPU power.
Is this normal? Is something bottlenecking the experience, maybe the optical drive or something?
Thank you for helping. Again, if this is fully expected behaviour, then I'm sorry for the waste of post.
Re: Very loww CPU usage when saving title
MakeMKV does not use a lot of CPU time. I've run several copies doing rips WHILE using handbrake to encode a file, and you barely see any change to CPU usage. 3% does not seem excessive or NONexcessive.
lomppu
Post by lomppu »
Thank you, good to know!
Leorelp
Post by Leorelp »
lomppu wrote:
Thu Aug 28, 2025 2:52 pm
Hi! That low CPU usage is actually normal for MakeMKV, since most of the work is being done by the optical drive reading the discs, not heavy processing on the CPU. As long as the ripping completes successfully, there’s no need to worry.
