Out of the currently manufactured UHD drives, which is the most reliable?
KeyNo
Post by KeyNo »
I'm sure that reliability is key to all of us, but out of the currently manufactured optical drives, which one is the most reliable? (bearing in mind that yes, of course, faults can develop and all things must eventually fail).
When it comes to reliability, is there one manufacturer who is better than the others?
Re: Out of the currently manufactured UHD drives, which is the most reliable?
This question gets asked with some regularity.
https://forum.makemkv.com/forum/viewtopic.php?p=181270#p181270
The short answer is a Pioneer if you can still find one. If not, something with a LG BU40N is probably the next best choice.
KeyNo
Post by KeyNo »
Thanks, will check the link.
