UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Stock levels updated in first post.
Do the "ready to go!" players support discs from all regions? We've got discs from multiple regions and would like to start ripping them to a media server so we're looking for a player that can handle all of those regions as well as newer 4k discs.
It's not the drive but the ripping software used that removes/ignores any region coding. MakeMKV doesn't care what region a disc is from and rips them anyway. I have many BD discs from all over the world, region A, B, C and have never had an issue ripping any of them with MakeMKV.tymon wrote: Mon Aug 04, 2025 2:36 am Do the "ready to go!" players support discs from all regions? We've got discs from multiple regions and would like to start ripping them to a media server so we're looking for a player that can handle all of those regions as well as newer 4k discs.
Just FYI, 4K UHD discs are region free.
Hi Marty,
Does this Pioneer BDR-S13C-X model can support UHD ripping, because your store is BDR-S13J-X that can't be found in the market, if I got this Pioneer BDR-S13C-X does this mocel can be flashed to support UHD rip, if yes, can you support I can pay you.
Thank!
Thank!
I don't want to make assumptions as I have never seen one of those before. I certainly don't recommend that Chinese version either.cqecho wrote: Sat Aug 23, 2025 1:24 pm Hi Marty,
Thank!
