Is my version of MakeMKV now toast for UHD ripping until the next update? *SOLVED*
Strange Angel
Post by Strange Angel »
So I'm very new to this and have been using GPT to help me along with some things. I recently got a new Verbatim 43888 drive, flashed the HL-DT-ST-BD-RE_BU40N-1.03 firmware from the pack on this forum, and popped in Heat 4K and got this string of errors:
"Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at &nEq#xL=:6?/jLfE:213130766 DEBUG: Code 3 at ,;C0yAY_BiPuE-x/)c:213131709 ... Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at ,;C0yAY_BiPuE-x/)c:121264395 DEBUG: Code 4 at ,;C0yAY_BiPuE-x/)c:213130789 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
and now even 4K discs I previously ripped can't be opened and I get the same error. GPT said this can happen where a disc who's keys have not been added to the database yet gets read by a drive, it can revoke the certificate of my version of MakeMKV, effectively bricking UHD ripping capability until a new version of MakeMKV is released. GPT says even if I use another confirmed working drive or re-install MakeMKV, it won't open UHD discs until the next update comes out because the certificate is baked into the sofware or something..
Is this tracking, am I SOL on UHD ripping until MakeMKV gets an update like GPT suggests, or is there a way around this?
Drive info:
Product: BD-RE BU40N
Revision: 1.05 (1.03 after flash)
Serial number: MO3P42D5134
Highest AACS version: 82
LibreDrive: Enabled
keydb_helper
Re: Is my version of MakeMKV now toast for UHD ripping until the next update?
Post by keydb_helper »
Strange Angel wrote: Thu Aug 28, 2025 1:26 am So I'm very new to this and have been using GPT to help me along with some things. I recently got a new Verbatim 43888 drive, flashed the HL-DT-ST-BD-RE_BU40N-1.03 firmware from the pack on this forum, and popped in Heat 4K and got this string of errors:
ChatGPT is absolutely useless for solving issues with MakeMKV.
Strange Angel wrote: Thu Aug 28, 2025 1:26 am "Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at &nEq#xL=:6?/jLfE:213130766 DEBUG: Code 3 at ,;C0yAY_BiPuE-x/)c:213131709 ... Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at ,;C0yAY_BiPuE-x/)c:121264395 DEBUG: Code 4 at ,;C0yAY_BiPuE-x/)c:213130789 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
This line indicates that LibreDrive is not currently active. UHD discs require LibreDrive to be active and functional.
Strange Angel wrote: Thu Aug 28, 2025 1:26 am and now even 4K discs I previously ripped can't be opened and I get the same error. GPT said this can happen where a disc who's keys have not been added to the database yet gets read by a drive, it can revoke the certificate of my version of MakeMKV, effectively bricking UHD ripping capability until a new version of MakeMKV is released.
MakeMKV only contains AACS 1.0 (1080p Blu-ray) host certificates. It has never contained an AACS 2.0 certificate so future updates have never resolved a UHD certificate revocation issue.
Strange Angel wrote: Thu Aug 28, 2025 1:26 am GPT says even if I use another confirmed working drive or re-install MakeMKV, it won't open UHD discs until the next update comes out because the certificate is baked into the sofware or something..
This was the most non-sensical part... Host certificate revocation works by maintaining a list of revoked host certificates within the drives non-volatile memory. Just because one of your drives may have an updated list of revoked host certificates this does nothing to any other disc drives you own.
Strange Angel wrote: Thu Aug 28, 2025 1:26 am Is this tracking, am I SOL on UHD ripping until MakeMKV gets an update like GPT suggests, or is there a way around this?
The way around this is to get LibreDrive working properly. Once LibreDrive is working properly your drive is effectively immune to any future host certificate revocations. You don't need to wait on an update for MakeMKV.
Can you post the drive info displayed by MakeMKV after you flashed your drives firmware? If it is still showing 1.05 it means that it was not successfully downgraded to the LibreDrive compatible firmware.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Strange Angel
keydb_helper wrote: Thu Aug 28, 2025 2:09 am
Thanks for offering to help. I appreciate it. As far as I can tell, the flash went fine and LibreDrive is enabled.
The drive info was in the body of my original post, but here it is again with the LibreDrive info as well now:
OS device name: E:
Revision: 1.03
Firmware version: 1.03
Would I start from here by just trying to reflash the drive?
Strange Angel wrote: Thu Aug 28, 2025 3:55 am
OS device name: E:
Revision: 1.03
No, the flash is good.
1. Power cycle the drive (at least 10 seconds)
2. Insert a disc
3. Wait for the OS to initialize the disc
4. Open MakeMKV and you should be good to go.
Strange Angel
MartyMcNuts wrote: Thu Aug 28, 2025 4:15 am
2. Insert a disc
I power cycled the drive and restarted my PC - popped in The Revenant 4K and the disc info reads fine, but when I go to open it I get the same issue - LibreDrive for some reason is not showing up as enabled in the debug screen - I get a whole string of errors that ends in this:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 3 at ,;C0yAY_BiPuE-x/)c:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\ramac/.MakeMKV/MKB20_v60_The_Revenant_0561.tgz
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
Strange Angel wrote: Thu Aug 28, 2025 4:23 am
2. Insert a disc
So, libredrive doesn't seem to be activating for some reason... Ok, you can try flashing it again. Since you are already on BU40N 1.03-MK, try flashing it to BU40N 1.00 then power cycle it again.
Always ensure you let Windows fully initialize the disc (you should be able to see it in windows explorer) before you open the MakeMKV application.
Strange Angel
MartyMcNuts wrote: Thu Aug 28, 2025 4:41 am
Thanks for all your help Marty! I really appreciate the support. During my fourth attempt at re-flashing and rebooting the drive, for shits and giggles I decided to switch which USB port it was connected to on the back of my motherboard. On my MSI X570 I have a row of 4 USB 3.2 ports. I switched which one of those 3.2 ports my drive was plugged in to by one and voila - LibreDrive is now recognized as enabled and actually functioning when I open a disc.
The weird part is I had my previous LG WH16NS40 and my Pioneer BDR-XS07UHD plugged into the same port and both worked fine. It's just this Verbatim that doesn't seem to like it. My guess is that one 3.2 port gets less stable power or signal integrity for whatever reason that was preventing LibreDrive from behaving properly on this specific drive.
