Dump v82 - How to train your dragon (2025)
navi1_de
Post by navi1_de »
i have the 4k UHD How to train your Dragon (2025) and will not work...
Here is my dumpfile and i hope it helps...
https://www.mediafire.com/file/l3vd1kp5 ... 8.tgz/file
Re: Dump v82 - How to train your dragon (2025)
navi1_de wrote:
Tue Aug 26, 2025 4:39 pm
Did you also email the dump file to svq@makemkv.com?
UHD FAQ
Public KeyDB Disc Submissions
navi1_de
Post by navi1_de »
Not yet...I thought maybe keydbhelper or even SamuriHL could help me find a key. I can also send the dump back to Mike...
Post by SamuriHL »
I don't do anything with keys myself but others will likely pick up your dump if it was created with an LG drive. My tool is for syncing the keydb to MakeMKV using FindVUK under the covers.
Post by SamuriHL »
looks like someone already added that one to the keydb.
disc id: 0x6885CCB0CD0CF7741AB4AA4D2C23B1BEA45C54CE
Use my tool to sync the keydb and MakeMKV will be able to open it.
navi1_de
Post by navi1_de »
@SamuriHL: Many thanks for your Disc-ID
I have your tool and tried it with your DiscID... makemkv runs and decrypts the movie...
Great, and thanks for your help in this case ;-)
Post by SamuriHL »
navi1_de wrote:
Thu Aug 28, 2025 4:37 pm
I wasn't the one to add this to the keydb. Someone else grabbed your dump before I got to it. All I did was get the disc id from your dump and checked that it was in the keydb. My tool has a search function for that very reason. Better yet the disc info button will tell you all kinds of fun things about your disc including the status of it in the keydb. Remember to always use the synchronize button before doing disc info or search to ensure you're looking at the latest keydb.
