encrypt firmware for BU40N or not
squattingcamera
Post by squattingcamera »
I recently bought a Verbatim 43888 with a BU40N inside and I want to flash the 1.03MK firmware to permanently enable LibreDrive, as recommended by the UHD flashing guide. The only thing I can't seem to find a definitive answer to is whether I should flash the firmware encrypted or not. My guess is, that the manufacturer-supplied firmware is encrypted, as the guide states that "firmware with date in 2020 is encrypted" and I bought the drive very recently. However, I am not able to find an unambiguous indication of whether I need to flash the MK firmware encrypted or not.
A clear way to determine whether the MK firmware needs to be encrypted for my drive would be greatly appreciated.
Below is the drive information.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO4P4TA5220
Highest AACS version: 78
Re: encrypt firmware for BU40N or not
1.05 is encrypted.
squattingcamera
Thank you!
Post by d00zah »
squattingcamera wrote: Wed Aug 27, 2025 8:01 pm I recently bought a Verbatim 43888 with a BU40N inside and I want to flash the 1.03MK firmware to permanently enable LibreDrive, as recommended by the UHD flashing guide. The only thing I can't seem to find a definitive answer to is whether I should flash the firmware encrypted or not. My guess is, that the manufacturer-supplied firmware is encrypted, as the guide states that "firmware with date in 2020 is encrypted" and I bought the drive very recently. However, I am not able to find an unambiguous indication of whether I need to flash the MK firmware encrypted or not.
Revision: 1.05
Yes, current FW is encrypted.
Ultimate UHD Drives Flashing Guide Updated 2025
Newer OEM Firmwares and encrypted:
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)
The recommended FW, "BU40N on any Firmware directly to > BU40N 1.03MK" is not. Use the 'enc' switch for the command line.
squattingcamera
