Help Needed: AACS v82 Blu-ray Rip Issue
ynwonss
Post by ynwonss »
I'm having trouble ripping a recently released Blu-ray that uses AACS v82 encryption. I attempted to rip it using MakeMKV v1.18.1, but it keeps failing and shows this error:
"This disc uses a newer version of AACS V82 protection."
I've already emailed the necessary information and am also attaching the related file here for reference:
https://drive.google.com/drive/folders/ ... drive_link
Any advice or workaround would be gently appreciated.
Thank you!
Re: Help Needed: AACS v82 Blu-ray Rip Issue
Did you use the key posted on the forum, or the old key that expired July 31?
ynwonss
Post by ynwonss »
Woodstock wrote: Tue Aug 26, 2025 6:44 pm Did you use the key posted on the forum, or the old key that expired July 31?
Yes, I’m using the latest key posted on the forum (the one valid until October 1), but I’m still getting the same error.
