Get the ugoos, all the other devices drop frames with FEL playback. CPM A14 has perfect playback and doesn't really need any update so we are good forever...
It cannot be explained better with fewer words.RESET_9999 wrote: ↑Tue Aug 26, 2025 5:46 pmGet the ugoos, all the other devices drop frames with FEL playback. CPM A14 has perfect playback and doesn't really need any update so we are good forever...
Decision made. I'm going for the Ugoos.
As always, thank you very much RESET_9999
deadchip12
Yes I downloaded the original clips and watched them on my a95l via the ugoos.RESET_9999 wrote: ↑Tue Aug 26, 2025 1:00 amThe Stranger Things, Liongates and Silo clips have slight banding/posterization in the source, but you should watch the original clips rather than the YouTube versions.
https://drive.google.com/drive/u/1/fold ... KkCkKrH3JG
The C2 and G5 show a lot of banding and posterization in HDR10, but DV is practically clean. My Samsung HDR10 monitor, on the other hand, shows no banding/posterization at all.
I did see mild banding/posterization mainly in those 3 clips.
Hopefully lg can fix the g5 and their future oleds, but I doubt it.
Well, my old C2 also has tons of banding/posterization in HDR10, so I guess LG indeed will never fix HDR10. Thankfully, they get DV right.deadchip12 wrote: ↑Tue Aug 26, 2025 11:38 pmYes I downloaded the original clips and watched them on my a95l via the ugoos.
Is there a difference between DV and HDR10 on the Sony?
On Samsung TVs and Monitors, the image is clean, so I suspect Samsung might be doing some undefeatable smooth gradation under the hood.
deadchip12
I don't see any obvious difference between hdr10 and DV on the Sony in terms of posterization.RESET_9999 wrote: ↑Wed Aug 27, 2025 12:41 amWell, my old C2 also has tons of banding/posterization in HDR10, so I guess LG indeed will never fix HDR10. Thankfully, they get DV right.deadchip12 wrote: ↑Tue Aug 26, 2025 11:38 pmYes I downloaded the original clips and watched them on my a95l via the ugoos.
The Samsung is completely clean even with the 3 clips you mentioned?
I talked to someone who had the new Samsung OLED TV but ended up returning it due to poor uniformity. He told me all the clips were completely free of banding and posterization.deadchip12 wrote: ↑Wed Aug 27, 2025 8:00 amI don't see any obvious difference between hdr10 and DV on the Sony in terms of posterization.
I only have a small Samsung OLED monitor for my PC, and it’s also pretty much clean, maybe with slight banding if you look very close. Funny thing is that my Samsung oled phone is worse than the G5 HDR10 and looks horrible.
Additionally, the G5 in HDR10 exhibits undefeatable dithering noise in all areas below 10 nits. Really a bad choice for anyone watching HDR10 content.
deadchip12
So strange. It dolby vision is clean on the g5, it means the panel tech is not the culprit, no? It also means there is no reason lg cant fix hdr10? I heard the panasonic z95b which uses the same panel has good hdr10 with almost no dithering noise, but bad dolby vision. It's like these manufacturers are intentionally playing with us.RESET_9999 wrote: ↑Wed Aug 27, 2025 11:08 amI talked to someone who had the new Samsung OLED TV but ended up returning it due to poor uniformity. He told me all the clips were completely free of banding and posterization.deadchip12 wrote: ↑Wed Aug 27, 2025 8:00 amI don't see any obvious difference between hdr10 and DV on the Sony in terms of posterization.
yeah I dont understand why they dont just do the same as DV.
Is ugoos still the only device to support Positive Lift(L2/L8 offset) and Level 5 Active area in TV-LED?RESET_9999 wrote: ↑Tue Aug 26, 2025 5:46 pmGet the ugoos, all the other devices drop frames with FEL playback. CPM A14 has perfect playback and doesn't really need any update so we are good forever...
windows 10/11 also supports it
I have a copy of both Superman's digital release with Dolby Vision and an ISO of the movie but somehow without Dolby Vision, just HDR. It's a legit copy otherwise. Is there a way for me to merge the DV stream to the MKV of the disc? I can send both to anyone who can help.
I've seen the tutorial but since the film's yet to be released until next month, I can't verify the plot.
You've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
it should have DV though: https://www.blu-ray.com/movies/Superman ... ay/378494/
It should have DV but here's the MediaInfo:RESET_9999 wrote: ↑Fri Aug 29, 2025 10:57 amYou've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
General
Unique ID : 217260551878948670668575265626170129968 (0xA372DC39FC159BF2603A5873170CFE30)
Complete name : C:\Video\Superman\Superman_t01.mkv
Format : Matroska
Format version : Version 2
File size : 59.6 GiB
Duration : 2 h 9 min
Overall bit rate mode : Variable
Overall bit rate : 65.9 Mb/s
Frame rate : 23.976 FPS
Title : Superman
Encoded date : 2025-08-28 02:31:42 UTC
Writing application : MakeMKV 1.18.1 win(x64-release)
Writing library : libmakemkv 1.18.1 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medi : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 60.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.306
Stream size : 55.0 GiB (92%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primar : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Le : 180 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medi : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 738 kb/s
Maximum bit rate : 5 781 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.38 GiB (6%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 592 MiB (1%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Dialog Normalization : -24 dB
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -24 dB
dialnorm_Minimum : -24 dB
dialnorm_Maximum : -24 dB
Audio #3
ID in the original source medi : 4353 (0x1101)
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Text #1
ID in the original source medi : 4768 (0x12A0)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 8 min
Bit rate : 51.9 kb/s
Frame rate : 0.446 FPS
Count of elements : 3450
Stream size : 47.9 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
ID in the original source medi : 4772 (0x12A4)
Format : PGS
Duration : 59 min 56 s
Bit rate : 635 b/s
Frame rate : 0.007 FPS
Count of elements : 25
Stream size : 279 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:09:17.557 : en:Chapter 02
00:17:50.069 : en:Chapter 03
00:26:45.604 : en:Chapter 04
00:36:45.203 : en:Chapter 05
00:43:40.618 : en:Chapter 06
00:50:22.019 : en:Chapter 07
00:58:31.508 : en:Chapter 08
01:07:28.044 : en:Chapter 09
01:16:36.592 : en:Chapter 10
01:23:50.025 : en:Chapter 11
01:31:11.466 : en:Chapter 12
01:39:03.938 : en:Chapter 13
01:49:01.535 : en:Chapter 14
01:59:00.133 : en:Chapter 15
02:08:21.694 : en:Chapter 16
Hmm, the back of the retail box shows Dolby Vision for sure, so unless it's weird authoring mistake, maybe you should also try and remux from .m2ts using mkvtoolnix or latest DGDemux to confirm?
uhdiznotenough4mee
Are you using some newer MediaInfo version or some old version?FLarnhill wrote: ↑Fri Aug 29, 2025 2:40 pmIt should have DV but here's the MediaInfo:RESET_9999 wrote: ↑Fri Aug 29, 2025 10:57 amYou've got the new superman uhd iso already? just submit it to makemkv and they will decrypt it and you will be able to plot it...
General
Format : Matroska
Title : Superman
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : No
Forced : No
Audio #1
Codec ID : A_TRUEHD
Bit depth : 24 bits
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dmixmod : Lt/Rt
Text #1
Format : PGS
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 635 b/s
Language : English
Default : No
Forced : No
Menu
