Dump v82 - How to train your dragon (2025)
i have the 4k UHD How to train your Dragon (2025) and will not work...
Here is my dumpfile and i hope it helps...
https://www.mediafire.com/file/l3vd1kp5 ... 8.tgz/file
Re: Dump v82 - How to train your dragon (2025)
Did you also email the dump file to svq@makemkv.com?navi1_de wrote: ↑Tue Aug 26, 2025 4:39 pmHi,
UHD FAQ
Public KeyDB Disc Submissions
Not yet...I thought maybe keydbhelper or even SamuriHL could help me find a key. I can also send the dump back to Mike...
I don't do anything with keys myself but others will likely pick up your dump if it was created with an LG drive. My tool is for syncing the keydb to MakeMKV using FindVUK under the covers.
looks like someone already added that one to the keydb.
Use my tool to sync the keydb and MakeMKV will be able to open it.
disc id: 0x6885CCB0CD0CF7741AB4AA4D2C23B1BEA45C54CE
@SamuriHL: Many thanks for your Disc-ID
I have your tool and tried it with your DiscID... makemkv runs and decrypts the movie...
Great, and thanks for your help in this case
I wasn't the one to add this to the keydb. Someone else grabbed your dump before I got to it. All I did was get the disc id from your dump and checked that it was in the keydb. My tool has a search function for that very reason. Better yet the disc info button will tell you all kinds of fun things about your disc including the status of it in the keydb. Remember to always use the synchronize button before doing disc info or search to ensure you're looking at the latest keydb.
eric_harrison
What tool? I'm new to the forum. Been using MakeMKV for a few years.SamuriHL wrote: ↑Wed Aug 27, 2025 11:43 pmlooks like someone already added that one to the keydb.
Use my tool to sync the keydb and MakeMKV will be able to open it.Code: Select all
KeyDB Helper (Windows Only)eric_harrison wrote: ↑Thu Sep 11, 2025 2:29 amWhat tool? I'm new to the forum. Been using MakeMKV for a few years.SamuriHL wrote: ↑Wed Aug 27, 2025 11:43 pmlooks like someone already added that one to the keydb.
eric_harrison
Guess I will have to turn my ripping machine into a Windows machine. Have you tested your tool on Win11?dcoke22 wrote: ↑Thu Sep 11, 2025 4:42 amKeyDB Helper (Windows Only)eric_harrison wrote: ↑Thu Sep 11, 2025 2:29 amWhat tool? I'm new to the forum. Been using MakeMKV for a few years.SamuriHL wrote: ↑Wed Aug 27, 2025 11:43 pmlooks like someone already added that one to the keydb.
eric_harrison
I got a different disc ID.
[(Disc Info)]
[DiscID]: 0x7F1113229A4CE20C087583E687914D6C06AF11B9
[Volume]: HOW_TO_TRAIN_YOUR_DRAGON_2025
[Title]: How to Train Your Dragon (2025)
[Date]: 2025-06-11
[MediaKey]: 0x8B96FBE7693A520B1F86A717F687E4EA
[VID]: 0x8A347653135A76C499DF12D8A3FA5FC7
[VUK]: 0x63D245FE858FFB6CE86FB6D9C9F0EF0E
[MKB]: 82
[UnitKey]: 1-0xBEB3E5337E73545F83A6F7E9E1F3EE81
[KEYDB_STATUS]: (VALIDATED)
[STATUS]: complete
[DiscType]: UHD
[(Disc Info)]
[Date]: 2025-06-11
[MKB]: 82
[STATUS]: complete
[DiscType]: UHD
eric_harrison
Guess this is a no go? ID is in the keydb.
Saving 1 titles into directory C:/Users/ehar8/OneDrive/Desktop/Rip
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '33330296832'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '33330296832'
Failed to save title 0 to file C:/Users/ehar8/OneDrive/Desktop/Rip/How to Train Your Dragon (2025)_t00.mkv
0 titles saved, 1 failed
Is libredrive enabled for your drive? You might need to reboot your drive (perhaps PC too!). When you start to rip the disc, ensure you see using libredrive mode in the log window.eric_harrison wrote: ↑Wed Sep 24, 2025 5:53 amGuess this is a no go? ID is in the keydb.
eric_harrison
Looks like it. I've ripped 4K Minecraft with no problem.
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL5O1CF5254
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: HOW_TO_TRAIN_YOUR_DRAGON_2025
Timestamp: 2025-06-11 11:55:54
Protection: AACS2.0/C v82
Data capacity: 85.62 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Then the drive might be having trouble reading that particular disc. This can also cause the drive to run out of juice. Have you tried cleaning the disc? If not, do so before attempting to rip it again.eric_harrison wrote: ↑Thu Sep 25, 2025 2:41 amLooks like it. I've ripped 4K Minecraft with no problem.
Revision: 1.02
Disc Information
Number of layers: 3
