Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
#241 Post by Billycar11 » Sun Aug 10, 2025 1:58 am
UHDforLIFE wrote: Sun Aug 10, 2025 1:41 am Hi, I have a BDR 212V and I would like a flash.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Bus encryption flags: 13
Firmware version: ID06
thanks!
sure email me that drive info section see below for email
carpler
#242 Post by carpler » Mon Aug 11, 2025 11:12 am
I purchased a Pioneer device on eBay.
I have no idea how to check whether the burner is new or used (any ideas?), but at the moment it seems to be working, even though I haven't made any ripping yet.
However, I would like to ask you this.
Here is the information returned by MakeMKV:
OS device name: I:
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: XXXXXXXXXXXXX
Firmware date: 2019-01-10
Highest AACS version: 78
Drive platform: RS8F00
Firmware version: 1.00/ID61
The unit arrived with the initial firmware, and it seems to be already unlocked as a LibreDrive device.
However, I understand that the firmware may be too old and unable to rip discs with recent AACS versions.
Do you suggest I update the firmware or leave it as it is?
What limitations would I have if I leave the current firmware?
Thank you for your attention!
#243 Post by Coopervid » Mon Aug 11, 2025 11:48 am
carpler wrote: Mon Aug 11, 2025 11:12 am I purchased a Pioneer device on eBay.
OS device name: I:
Revision: 1.00
The drive is fairly old but it should be OK. I will send you a PM that allows also ripping of UHD discs. Regarding the newest AACS dumps have to be sent from a non-Pioneer drive but you can always use the keydb.cgf file. Read this thread:
viewtopic.php?f=12&t=38293
NathanielHornblower
#244 Post by NathanielHornblower » Thu Aug 21, 2025 3:43 am
Hello again,
The two drives I ordered arrived. Unboxed one and put in the OWC case (Thanks for the rec, Billy!) and here's the info:
Revision: 1.02
Serial number:
#245 Post by Billycar11 » Thu Aug 21, 2025 6:38 am
NathanielHornblower wrote: Thu Aug 21, 2025 3:43 am Hello again,
Revision: 1.02
Serial number:
no problem just email that over to me for the flasher see below
ihavoc
#246 Post by ihavoc » Tue Aug 26, 2025 2:15 pm
Hello, if someone can PM me with what I need for my BDR-212V thank you
Revision: 1.02
Serial number: DGDL028112WL
#247 Post by Coopervid » Tue Aug 26, 2025 6:10 pm
ihavoc wrote: Tue Aug 26, 2025 2:15 pm Hello, if someone can PM me with what I need for my BDR-212V thank you
Revision: 1.02
PM sent.
flojo
#248 Post by flojo » Thu Aug 28, 2025 10:52 pm
FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
This is frivolous information to most, but it's a landmark for me as I never thought disc GOTUHD_S7_D2_B5 would rip :-/
#249 Post by MartyMcNuts » Thu Aug 28, 2025 11:45 pm
flojo wrote: Thu Aug 28, 2025 10:52 pm FWIW, I just successfully ripped all 30 UHD discs of the "Game Of Thrones: The Complete Collection" UHD box set using a Pioneer BDR-212V in a OWC Mercury Pro (OWCMR3UKIT) enclosure.
It's amazing how much better Pioneer drives are!!
#250 Post by Billycar11 » Fri Aug 29, 2025 1:03 am
MartyMcNuts wrote: Thu Aug 28, 2025 11:45 pm
i know but so many dont believe us and think we are shills
#251 Post by MartyMcNuts » Fri Aug 29, 2025 1:48 am
Billycar11 wrote: Fri Aug 29, 2025 1:03 am
Yep, we say these things just for shits and giggles!
macep
#252 Post by macep » Sat May 16, 2026 12:40 am
Coopervid wrote: Mon Dec 16, 2024 10:29 pm And yes we checked that wit LG WH16NS58 1.V5 and VPTools. All newer multilayer discs after Verbatim moved the equipment to Taiwan have issues at the layer break. 50 Gb Ritek are still Ok. Were. These tests are 2 years old. Advice: Stop burning discs!
Hi, sorry for replying to an old post, but could you advice me where I can download LG WH16NS58 1.V5 and VPTools? I just purchased BUFFALO BRXL-16U3 and am trying to make it a BD quality scanner. Thank you in advance.
#253 Post by Coopervid » Sat May 16, 2026 9:12 am
macep wrote: Sat May 16, 2026 12:40 am
I replied to your PM. Is this Buffalo a full size drive with the MT1959 chip? The safest way to check is posting or sending your Makemkv info.
