Crossflash for Verbatim BU40N 1.05
Palpex
Re: Crossflash for Verbatim BU40N 1.05
Post by Palpex »
Coopervid wrote: Fri Aug 22, 2025 2:56 pm
Palpex wrote: Fri Aug 22, 2025 12:32 pm
zittrig wrote: Fri Apr 04, 2025 12:51 pm Flash directly to 1.03MK.
Tool and firmware packages you can find there ------> viewtopic.php?f=16&t=22896
Hi, ive got the exact same device, tried flashing both to version 1.03/4 MK but i always get the error: "Command produced error code 0xff056103"
Is this a know issue?
Are you using SDFTool flasher or a command line? Windows or other OS? Post your Makemkv info or copy&paste the error message.
Im using SDFTool flasher on Windows 11.
this is the info output:
MSG:1005,0,1,"MakeMKV v1.18.1 win(x86-release) gestartet","%1 gestartet","MakeMKV v1.18.1 win(x86-release)"
MSG:1011,0,1,"You are running a 32-bit (x86) version of a program. Eventually this will be deprecated in upcoming versions, please upgrade to a processor manufactured during last 10 years...","%1","You are running a 32-bit (x86) version of a program. Eventually this will be deprecated in upcoming versions, please upgrade to a processor manufactured during last 10 years..."
DRV:0,1,999,0,"BD-RE HL-DT-ST BD-RE BU40N 1.05 MO4P4TG1043","","H:"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
Use: makemkvcon [switches] Command [Parameters]
MakeMKV Programm Info:
Laufwerksinformation
OS-Gerätename: H:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.05
Serienummer: MO4P4TG1043
Firmware-Datum: 2124-04-23 13:47
Markierungen der Bus-Verschlüsselung: 17
Palpex
Post by Palpex »
MartyMcNuts wrote: Sat Aug 23, 2025 12:14 am
Ensure there is no disc in the drive.
Tried again with not disc, and with "Include boot loader" both enabled and disabled, still exact same error message
tomcat1511
Post by tomcat1511 »
Billycar11 wrote: Sun Aug 24, 2025 11:18 pm Then don't flash it well you already did probably dead
It's not dead, just working as usual. But also no improvement with playing 4K.
Maybe someone else can help, maybe I overlooked something in the process.
tomcat1511 wrote: Mon Aug 25, 2025 10:46 am
weird over in the usa we got none of those svc nb 40 drives that had nb50/52 hardware very strange
if it had that svc code here and you did that it would be dead
