Idk what's happening
AaronB
Post by AaronB » Sun Aug 24, 2025 11:59 pm
So I'm trying to rip my 4K Blu-Ray of The Wild Robot but whenever I try to rip it something is failing here is the log
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
File 00801.mpls was added as title #0
File 01238.mpls was added as title #1
File 01241.mpls was added as title #2
File 00149.mpls was added as title #3
Title #01041.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01042.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01048.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00040.mpls is equal to title 00801.mpls and was skipped
Title #01064.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01065.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01066.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01067.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01258.mpls was added as title #4
File 01259.mpls was added as title #5
File 01260.mpls was added as title #6
File 01261.mpls was added as title #7
File 01262.mpls was added as title #8
File 01263.mpls was added as title #9
File 01264.mpls was added as title #10
File 01265.mpls was added as title #11
File 01266.mpls was added as title #12
Title #00174.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00293.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00240.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00241.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00242.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00243.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00217.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00254.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00255.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00256.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00257.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00258.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00259.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00261.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00262.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00263.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00264.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00265.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00266.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00267.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00268.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00269.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00270.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00271.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00278.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00281.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00284.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00285.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00286.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00287.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00288.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00289.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00290.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00291.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00292.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00294.m2ts was added as title #13
Title #00340.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00296.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00435.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00436.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00437.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00438.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00439.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00440.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00441.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00442.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00443.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00444.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00445.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00446.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00447.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00448.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00453.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00454.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00455.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00456.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00457.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00458.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00459.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00460.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00461.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00463.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00464.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00465.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00467.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00468.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00469.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00470.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00471.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00472.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00473.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00475.m2ts was added as title #14
File 00476.m2ts was added as title #15
File 00478.m2ts was added as title #16
File 00479.m2ts was added as title #17
File 00480.m2ts was added as title #18
File 00481.m2ts was added as title #19
File 00482.m2ts was added as title #20
File 00483.m2ts was added as title #21
File 00484.m2ts was added as title #22
Title #00485.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00486.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00487.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00488.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00489.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00490.m2ts was added as title #23
Saving 1 titles into directory S:/Plex/In Progress
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '21036201984'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '21036201984'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '21036201984'
Failed to save title 0 to file S:/Plex/In Progress/The Wild Robot_t00.mkv
Encountered 18 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '21036595200'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '21036595200'
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Re: Idk what's happening
Post by Woodstock » Mon Aug 25, 2025 12:06 am
Most likely, your drive is shutting down due to insufficient power as it tried to speed up to read the disk. There are a couple of ways to deal with that - primary being to make sure you have sufficient power. Assuming a USB2 drive, using a dual-input cable, using different USB ports, can work, or using a USB3 cable to power the drive.
AaronB
Post by AaronB » Mon Aug 25, 2025 12:19 am
I'll check but I'm pretty sure I'm using a 3.1 type C cable with a 3.2 port
Post by MartyMcNuts » Mon Aug 25, 2025 12:44 am
AaronB wrote: Mon Aug 25, 2025 12:19 am I'll check but I'm pretty sure I'm using a 3.1 type C cable with a 3.2 port
If USB-C, use either a port direct from motherboard (not case ports!) or an AC self-powered USB hub of at least 30W.
AaronB
Post by AaronB » Mon Aug 25, 2025 10:21 pm
it is a port directly on the motherboard. I also don't know if this is the same issues or a different one. Before I went to bed I tried ripping The Batman (Robert Patterson) and after a little while of ripping fine eventually it just stopped and wouldn't progress it would only increase the estimated time.
AaronB
Post by AaronB » Mon Aug 25, 2025 10:23 pm
File 01001.mpls was added as title #0
File 01002.mpls was added as title #1
File 01003.mpls was added as title #2
File 01004.mpls was added as title #3
File 01005.mpls was added as title #4
File 01006.mpls was added as title #5
File 01007.mpls was added as title #6
File 01008.mpls was added as title #7
File 01009.mpls was added as title #8
File 01010.mpls was added as title #9
File 01011.mpls was added as title #10
File 01012.mpls was added as title #11
File 01013.mpls was added as title #12
File 01018.mpls was added as title #13
Title 00000.m2ts is equal to title 01001.mpls and was skipped
Title 00001.m2ts is equal to title 01002.mpls and was skipped
Title 00002.m2ts is equal to title 01003.mpls and was skipped
Title 00003.m2ts is equal to title 01004.mpls and was skipped
Title 00004.m2ts is equal to title 01005.mpls and was skipped
Title 00005.m2ts is equal to title 01006.mpls and was skipped
Title 00006.m2ts is equal to title 01007.mpls and was skipped
Title 00007.m2ts is equal to title 01008.mpls and was skipped
Title 00008.m2ts is equal to title 01009.mpls and was skipped
Title 00009.m2ts is equal to title 01010.mpls and was skipped
Title 00010.m2ts is equal to title 01011.mpls and was skipped
Title 00011.m2ts is equal to title 01012.mpls and was skipped
Title 00012.m2ts is equal to title 01013.mpls and was skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #14
Title #00016.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.mpls was added as title #0
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #2
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00059.m2ts was added as title #3
Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00075.m2ts was added as title #4
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858530304, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858530304-15858536448, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858536448, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858536448-15858542592, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858542592, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858542592-15858548736, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 15858548736, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00075.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00075.m2ts at offset 15858591744, file is corrupt.
Hash check failed for file 00075.m2ts at offset 15858788352, file is corrupt.
Hash check failed for file 00075.m2ts at offset 15858984960, file is corrupt.
Hash check failed for file 00075.m2ts at offset 15859181568, file is corrupt.
Hash check failed for file 00075.m2ts at offset 15859378176, file is corrupt.
Too many hash check errors in file 00075.m2ts.
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007055360, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007055360-16007061504, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007061504, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007061504-16007067648, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007067648, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007067648-16007073792, attempting to work around
The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 16007073792, attempting to work around
Failed to save title 1 to file S:/Plex/In Progress/The Batman_t01.mkv
Encountered 1273 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
