Longshot with Pioneer BDR-209D
epicfx37355
Re: Longshot with Pioneer BDR-209D
Thanks, it is saying drive and firmware hardware types don't match
Ensure you check the box to force flash.epicfx37355 wrote: Sun Aug 24, 2025 12:37 am Thanks, it is saying drive and firmware hardware types don't match
epicfx37355
Thanks. That worked
epicfx37355
I need your country. send me a pm please
shinderoo
Hi Coopervid,
Can you please give me a hand on turning my drive into UHD friendly? Thanks in advance!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51/ID61
OS device name: E:
Revision: 1.51
Serial number:
PM sent.shinderoo wrote: Sun Aug 24, 2025 7:34 am Hi Coopervid,
OS device name: E:
Revision: 1.51
Serial number:
ben8472
Hi Coopervid,
can you please give me a hand also on turning my BDR-209D to UHD? Thank you!
OS device name: G:
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Firmware version: 1.20/ID61
OS device name: G:
Revision: 1.20
Serial number:
PM sent.ben8472 wrote: Thu Sep 04, 2025 9:34 am Hi Coopervid,
OS device name: G:
Revision: 1.20
Serial number:
ben8472
thank you, it worked! (couldn't reply on PM unfortunately) Donation sent.
senna78
Hi Coopervid,
I have a Pioneer BDR-209D here that I would like to flash so that I can rip UHD discs.
Unfortunately, my BH16NS55 occasionally causes problems.
OS device name: /dev/sr1
Revision: 1.50
Serial number: xxxxxx
Firmware date: 2017-12-21
Highest AACS version: 77
Drive platform: RS8601
Firmware version: 1.50/ID61
I would appreciate your help.
Thank you in advance!
Best Regards
Revision: 1.50
Best Regards
PM sent.senna78 wrote: Wed Sep 10, 2025 2:10 pm Hi Coopervid,
Revision: 1.50
Best Regards
senna78
Thanks a lot, donation sent!
senna78
Hi Coopervid,
I got another Pioneer BDR-209DBK.
However, the MakeMKV info shows Drive platform: RS8600 instead of RS8601 like on my first drive.
Can I flash the same firmware here, or do I need a different one?
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Firmware version: 1.34/ID61
One more question
Is it possible to flash back to the original firmware after cross-flashing?
If so, can I back up the original firmware before cross-flashing, or can I just use the firmware available from Pioneer?
Does it even make sense to flash back, or are the drive specifications the same after cross-flashing, except for UHD support?
Thank you in advance for your help.
Best regards
Revision: 1.34
Serial number:
One more question
Best regards
saegezauberer
Hi Coopervid,
could you please also help me to flash my drive into a UHD compatible one?
OS device name: E:
Revision: 1.51
Serial number:
I would really appreciate your help.
Best Regards
OS device name: E:
Revision: 1.51
Serial number:
Best Regards
PM sent.saegezauberer wrote: Tue Sep 23, 2025 3:47 pm Hi Coopervid,
OS device name: E:
Revision: 1.51
Serial number:
Best Regards
