BU40N Flash Hangs
tauceti
BU40N Flash Hangs
Post by tauceti » Sun Aug 24, 2025 1:40 am
I'm trying to flash a BU40N drive from version 1.05 -> 1.03 (see further below for full details of the drive). However, when I run the command:
makemkvcon f -d 'dev_21:4' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
It hangs forever with no progress. I am able to still use the drive after killing the command.
Followed instructions from viewtopic.php?p=181425#p181425 to flash on a linux device. I have no disc in the drive.
How can I troubleshoot this? I include more details below. Thanks!
Command:
makemkvcon f -l
Found 2 drives(s)
00: dev_21:4, /dev/sr1, /dev/sr1
HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MOBP4291705
[omitted second drive]
md5sum of the two files used:
$ md5sum sdf.bin HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
602b0be6847e9623f7454ac2b87df80d sdf.bin
74ebaf627d2aac5f899191d6caceb54c HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Drive Info:
OS device name: /dev/sr1
Product: BD-RE BU40N
Revision: 1.05
Serial number: XXX
Re: BU40N Flash Hangs
Post by Billycar11 » Sun Aug 24, 2025 3:23 am
well you dont have enc but thats probably not the problem though
last few version have a flashing bug on linux go back to 1.17 and try with enc and it should work and go to 1.00 after 1.03 as on linux there is also a bug that 1.03mk does not work only the de fw does
tauceti
Post by tauceti » Sun Aug 24, 2025 12:48 pm
Thanks. I ended up addressing this in windows. I'm not sure why it doesn't work in linux. MakeMKV recognizes my drive but would also freeze when trying to load a bluray disc (that I could load in windows; it's not UHD).
What's interesting is that when I would start MakeMKV in linux, it would launch a process `makemkvcon`, which would just hang forever. When killing MakeMKV, I would have to manually kill this process myself.
After flashing in Windows, MakeMKV works in Linux. I also don't see that hanging process named `makemkvcon` anymore.
Here is what I did and the relevant output below/
First, I followed https://github.com/nxyzo/Flashing-Verba ... -to-1.03MK
Double checked my drive worked by loading a disc in windows (unlike linux, the disc loads):
Revision: 1.05
Serial number: XXXXXX
Highest AACS version: 78
Disc Information
Label: Stargate_SG1_BR_S5D2
Timestamp: 2021-01-22 12:12:47
Protection: AACS v78
Data capacity: 34.82 Gb
Disc type: BD-ROM
Number of layers: 2
I then ran this at command line (powershell):
./makemkvcon64.exe f --all-yes -d D: rawflash enc -i "C:\Users\jrmlh\projects\bluray\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
and got this output:
./makemkvcon64.exe f --all-yes -d D: rawflash enc -i "C:\Users\XXX\projects\bluray\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
Reading input file C:\Users\XXX\projects\bluray\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MOBP4291705
100% Operation finished
Done successfully
After this, I now see this output in linux when test loading a disc:
Revision: 1.03
Serial number: XXX
Firmware version: 1.03
Disc Information
Disc type: BD-ROM
Number of layers: 2
Post by MartyMcNuts » Mon Aug 25, 2025 1:03 am
Revision: 1.05
Disc Information
Disc type: BD-ROM
Number of layers: 2
Done successfully
Revision: 1.03
Serial number: XXX
Disc Information
Disc type: BD-ROM
Number of layers: 2
I suggest you now flash the drive to BU40N 1.00 as BU40N 1.03-MK doesn't work very well on Linux.
gabiel
Post by gabiel » Tue Sep 09, 2025 9:42 pm
Hi MartyMcNuts,
I have a couple of questions regarding the flashing of BU40N to 1.00:
  1. The procedure is the same as flashing to 1.03?
  2. Can it be done directly from stock firmware or the drive should be flashed first to 1.03?
  3. Do you have a link to the issues of 1.03 on Linux? I tried searching the forum but I cannot find any specific issue, only other post stating that there are issues
Thanks for your time.
NGNXM8
Post by NGNXM8 » Mon Sep 15, 2025 10:55 pm
Hey Gabiel!
There are no issues with 1.03 on Linux i backed up 3 UHD discs just a few hours ago on it.
The only thing that is broken, is makemkvcon after version 1.17.6, so you cant flash drives on linux with newer versions.
Post by MartyMcNuts » Tue Sep 16, 2025 1:33 am
Hi MartyMcNuts,
Yes
No
No. There are quite a few posts in various threads on the forum. I think it's more of a MakeMKV issue (Linux version), not a firmware issue.
gabiel
Post by gabiel » Tue Sep 16, 2025 7:18 pm
Ok, I will stay with 1.03 then. Thank you very much for your answers NGNXM8 and MartyMcNuts.
Regards.
