All Pioneer drives will be LibreDrive supported
Dromeosaurid
Re: All Pioneer drives will be LibreDrive supported
This is great news!
MovieNut
Looking forward to this as well. I will have several Pioneer drives waiting.
VA1DER
"Near" is open to interpretation.MartyMcNuts wrote: Tue Aug 19, 2025 10:58 pm Yeah, but they most likely will be supported in the near future.
That said...
The slimlne XS08 and even the UD04 you can still sort of get UHD-patchable versions of now are good drives, but actual S series 5. 25" drives are the best there are. I don't know how long before S12/S13 (or X12/X13) drives made after Dec 2022 will be libre drive patchable, but the consensus is they definitely will be. And when they are, what little stock there is of those drives now will turn into genuine unobtanium.MartyMcNuts wrote: Tue Aug 19, 2025 10:58 pmAlso, since Pioneer ceased manufacturing optical drives several months ago, the worlds supply is dwindling rather quickly!
Now is the time to spring for one, or forever hold your peace.
cheeseballs
This is probably a stupid question but will ask anyway-
Recently bought a random external drive on Amazon and it turned out to be a Pioneer BDR-206. I know Mike said 'all' Pioneer drives will be supported but I saw some older posts saying that only 208 or higher are UHD compatible. I'm still within my return window so wondering if I should return or hold onto it?
If you want to rip UHD, return it. Even if it does get libredrive enabled, it still won't read UHD discs.cheeseballs wrote: Sat Aug 23, 2025 11:13 pm This is probably a stupid question but will ask anyway-
Mr_Orange
Where does the BDR-212DBK sit in the pecking order? Will this ever be UHD Libredrive?
It's the base model, almost the same as the 212V. It can be cross-flashed for UHD redability.Mr_Orange wrote: Sat Aug 23, 2025 11:45 pm Where does the BDR-212DBK sit in the pecking order? Will this ever be UHD Libredrive?
bruce_ld
I realize that the project of reverse engineering and bypassing the locked firmware must be extremely complex. However, I was wondering if there had been any updates on the timeline recently?
Thanks so much, mike!
-Bruce
-Bruce
pronouns: she/he
pronouns: she/he
socdaemon
+1, just here to share my appreciation for this effort! I'm patiently waiting for a way to unlock my BDR-XD08B for UHD
Thank you!!
Thank you!!
DarkFiber
Same here. I'm under no illusions that this will be a trivial hack, but it's almost exactly 5 months now, without any sort of update.
Is this still underway? Thanks!
Voxelium
I stumbled across the following thread:
https://www.reddit.com/r/makemkv/commen ... t/nhi6gvh/
According to Billy, it looks like the wait is almost over. Fingers crossed my XS07S is compatible!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ttubbs
Any more news on this? I already have an Asus BW-16D1HT and an LG slim. I would love to add a Pioneer to the lot.
Voxelium
Check that Reddit thread in the reply I made above yours.ttubbs wrote: Sat Oct 11, 2025 4:30 am Any more news on this? I already have an Asus BW-16D1HT and an LG slim. I would love to add a Pioneer to the lot.
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
ChameleonScales
Thank you so much for doing God's work.
I have a noob question : will this lift some hardware restrictions that some drives have? Specifically, I have a BDR-XS07UHD which requires specific Intel CPU and GPU tech but my PC has an AMD Ryzen 9 CPU + Nvidia 4090.
Hardware restrictions for what? If you are talking about UHD disc playback, although direct UHD disc playback is not recommended, it can be done on any decent spec PC (including yours) using any UHD compatible libredrive enabled drive via an unofficial player such as VLC, MPC_HC, Jriver, etc once integrated with MakeMKV.ChameleonScales wrote: Sun Oct 12, 2025 6:34 pm Hi,
