BDR 212V UHD Guide
Frying-Tux
Re: BDR 212V UHD Guide
Post by Frying-Tux » Mon Aug 18, 2025 6:58 pm
Hi Coopervid! I too would like a PM with instructions to get my drive working. Thank you!
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 15
Firmware version: ID06
Post by Coopervid » Wed Aug 20, 2025 8:42 am
Frying-Tux wrote: Mon Aug 18, 2025 6:58 pm Hi Coopervid! I too would like a PM with instructions to get my drive working. Thank you!
Revision: 1.02
Serial number: XXXX
PM sent. You need a Windows PC or VMWare under Linux. Not all VMs work.
bobbles
Post by bobbles » Fri Aug 22, 2025 3:36 am
Hi there, Coopervid! I recently picked up a BDR-212V as a backup when I heard Pioneer was getting out of the business, and I'd like to get it working with LibreDrive. I'd appreciate hearing from you!
Revision: 1.02
Serial number: DGDL028725WL
Highest AACS version: 82
vatov
Post by vatov » Fri Aug 22, 2025 2:11 pm
Coopervid wrote: Sun May 19, 2024 11:16 pm
squatch316 wrote: Sun May 19, 2024 10:46 pm
Read your PM.
Good day @Coopervid,
I know this is an old post but hopefully you're still active
I have a Pioneer VD-RW BDR-212V still running Firmware 1.00
Could you please share your guidance!
Thank you
Post by Coopervid » Fri Aug 22, 2025 2:53 pm
vatov wrote: Fri Aug 22, 2025 2:11 pm
Read your PM.
Thank you
To play it safe post your Makemkv info.
nfodiz
Post by nfodiz » Fri Aug 22, 2025 9:04 pm
Greetings Coopervid! I recently ordered a BD-RW BDR-212V to use before inventory dries up completely. I also would love some guidance.
Here is my info from makemkv
OS device name: E:
Revision: 1.02
Serial number: xxxxxxxxxxx
Thank you!
Post by Coopervid » Fri Aug 22, 2025 10:35 pm
nfodiz wrote: Fri Aug 22, 2025 9:04 pm Greetings Coopervid! I recently ordered a BD-RW BDR-212V to use before inventory dries up completely. I also would love some guidance.
OS device name: E:
Revision: 1.02
Thank you!
PM sent.
bobbles
Post by bobbles » Sat Aug 23, 2025 3:48 am
Hi, Coopervid! I think my previous message waiting in the moderation queue (I'm a new registrant) means you might have missed it, and I can't send PMs yet, so sorry if this is repeating a message you've already seen.
Revision: 1.02
Serial number:
AndyA
Post by AndyA » Sat Aug 23, 2025 10:23 pm
Yet another one
Revision: 1.02
Serial number: DGDL028102WL
Highest AACS version: 68
Just curious. When I put a DVD in the drive, makemkv just spins trying to load the disc.
I can mount the drive and see the directory structure. So the drive appears to work, and this disc works fine in other drives.
Do we expect to get makemkv to do anything with this drive in stock form? Or is the reflash required for all types of discs?
Post by Billycar11 » Sat Aug 23, 2025 11:27 pm
AndyA wrote: Sat Aug 23, 2025 10:23 pm Yet another one
Revision: 1.02
Let the os see the disc first then open makemkv
vatov
Post by vatov » Sun Aug 24, 2025 10:39 am
Coopervid wrote: Fri Aug 22, 2025 2:53 pm
Read your PM.
Thank you
MakeMKV info tab:
OS device name: F:
Revision: 1.00
Serial number: AFDL013220WL
Firmware date: 2020-08-07
Highest AACS version: 70
Drive platform: RS8F00
Firmware version: 1.00/ID06
Please let me know if you need other information
Thank you
Post by Coopervid » Sun Aug 24, 2025 3:03 pm
vatov wrote: Sun Aug 24, 2025 10:39 am
Thank you
MakeMKV info tab:
OS device name: F:
Revision: 1.00
Thank you
PM sent.
willkg118
Post by willkg118 » Sun Aug 24, 2025 7:30 pm
Greetings @Coopervid
I saw this thread. I hope you're reading it. I just bought a Pioneer BDR-212V. I'm hoping these specs show that I'm able to flash its firmware
Current profile: DVD-ROM
Revision: 1.02
Serial number: REMOVED
I hope this version is good. thank you in advance!
- Will
Post by Coopervid » Sun Aug 24, 2025 8:35 pm
willkg118 wrote: Sun Aug 24, 2025 7:30 pm Greetings @Coopervid
Revision: 1.02
- Will
PM sent.
RobertTX
Post by RobertTX » Sun Aug 24, 2025 9:21 pm
Just joined the group and hope you can help me flash my drive.
Info follows:
OS device name: G:
Revision: 1.02
Serial number:
Thank you in advance
