Pioneer BDR-S13JX No Longer Reads Blu Media
ZZorrander
#1 Post by ZZorrander » Sat Aug 23, 2025 6:29 pm
I've had this S13JX for about a year and had zero issues with it until this morning when it suddenly decided it would no longer read Blu media. It reads a DVD without issues, but not Blu I tried a power cycle, rebooting PC, etc. The drive spins up and acts like it's seeking, then just gives up and says no disc inserted. I have it in a Vantec case, so I removed it and lightly blew a little canned air in through the open tray thinking maybe some fuzz got in there, but it still will not read Blu media. I thought this thing would outlast me considering what it cost. I hate to think that it has failed and cannot be replaced. Is it worth trying to open up to see what's going on or would you just get something else?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: DDDL930125UC
Firmware date: 2022-07-26
Highest AACS version: 81
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Re: Pioneer BDR-S13JX No Longer Reads Blu Media
#2 Post by Billycar11 » Sat Aug 23, 2025 10:55 pm
Clean the lasers here's how.
eject tray
unplug drive with tray out
pop off front bezel clips on sides and bottom with plastic tool
undo screws from bottom will be under stickers if you have an s13, 213 does not have stickers.
flip backover and remove top cover
clean lasers with a lint free cloth or qtip and alcohol and dry with another do this 2 times and do not let it air dry you must remove the residue with a dry one!
ZZorrander
#3 Post by ZZorrander » Sat Aug 23, 2025 11:47 pm
Thank you, this did the trick. Not as much gadgetry in there as I figured there would be. :D :D :D :D
