Disc is being loaded
Doomlord
#1 Post by Doomlord » Sat Aug 23, 2025 8:35 am
Hi. My first post!
I have been trying to get MakeMKV working on my computer.
I'm running Fedora Linux 42 (Gnome 48) and 6.15.10-200.fc42.x86_64 Kernel
I have 2 external drives
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Firmware version: ID76
And
Product: BD-RE BU40N
Revision: 1.05
Serial number:
Disc Information
App loads just fine, but all I get after loading a disc is: Disc is being loaded... Nothing happens after that!
Same problem with both drives and with Blu-ray and DVD discs. Ripping same DVDs with Handbrake works just fine.
First I tried installing MakeMKV from Flatpack, and after that i downloaded and compiled the source code from this forum.
Same problem with both methods :(
About section:
MakeMKV v1.18.1 (Linux(x64-release))
GUI version: v1.18.1 (for x86_64-redhat-linux)
Evaluation expires Wed Oct 1 2005 (38 days)
Any ideas what might be wrong?
wmcclain
Re: Disc is being loaded
#2 Post by wmcclain » Sat Aug 23, 2025 1:57 pm
Many Linux users (and me) report 1.8.x is not working well. Solution for now is to install 1.17.7.
For discussion see: viewtopic.php?f=3&t=37670
Doomlord
#3 Post by Doomlord » Sat Aug 23, 2025 3:58 pm
Thanks for your help.
Ok I’ll try installing older version.
Doomlord
#4 Post by Doomlord » Sat Aug 23, 2025 7:21 pm
Can confirm compiling 1.17.7 works like a charm!
Thanks again.
hey_its_me_25
#5 Post by hey_its_me_25 » Sun Aug 24, 2025 4:58 pm
Doomlord wrote: Sat Aug 23, 2025 7:21 pm Can confirm compiling 1.17.7 works like a charm!
Thanks again.
Hello @Doomlord
I have the same problem but I dont know how to get an older version of MakeMKV working? I can just download the new version via package manager.
Would be great if you can tell me how to install version 1.17.7 :)
wmcclain
#6 Post by wmcclain » Sun Aug 24, 2025 8:17 pm
You need to compile the packages. Follow the instructions here: viewtopic.php?f=3&t=224
Instead of the latest makemkv-oss and makemkv-bin files, find the older versions here: https://www.makemkv.com/download/old/
Use gunzip first before using tar to unpack both archives.
hey_its_me_25
#7 Post by hey_its_me_25 » Mon Aug 25, 2025 1:03 pm
Thank you very much for your links and help. With their help, I managed to get version 1.17.7 up and running. I can work with Blu-rays without any problems. Unfortunately, UHD discs don't work.
What I don't understand is that until about two months ago, I was able to use the latest version of MakeMKV without any problems. Based on the timestamps, that must have been version 1.17.9. Maybe I'll try that version again and hopefully the UHD discs will work again.
